Auto Discover Vs Manual Entry
I’ve got Hass.IO up and running coming over from OpenHAB and am finding is easier to get running which is great. I have my Sonoff units added in the confi.yml file:
switch:
    - platform: mqtt
      command_topic: "cmnd/SF_01/power"
      state_topic: "stat/SF_01/POWER"
      qos: 1
      payload_on: "ON"
      payload_off: "OFF"
      retain: true
When i went to do an automation from the web GUI, i was unable to select the device. Looked in the Configuration> Devices andit’s not listed.
Doing some reading found that i can turn on auto discovery using SetOption19 1 in Tasmota. This then meant HASS.IO discovered my device and was listed in devices :slight_smile: YEA!
And my automation would then worked!
Problem is i have other devices like a NodeMCU that i added manually and want to aopear in my automation’s for selection. Anyone see what i am missing?
Thanks in advance
if the discovery worked ok, then your MQTT Broker is working fine. It’s then probably an issue with your state_topic.
Have you tried another tool (like mqtt.fx) to see if you receive any messages on “stat/SF_01/POWER” ?
If you added your nodeMCU manually, it will not show up as a device.
it won’t show up as a device as noted above but you can still use it in any automation you want by referencing it’s entity_id.
