Auto-discovery of homeassistant docker container behind NGINX reverse proxy
I have a home assistant install running in a docker container on a raspberry pi behind an NGINX proxy so I can do additional authentication and hardening. I have the NGINX forwarding both port 80 and port8123 to the container and I can log into the app using the reverse proxied domain name. However the one piece I am missing is the auto detect. Currently when I open the app it autodetects the ip address not the domain name. And when I bind the docker container to localhost to pass all traffic through the nginx the auto-discovery breaks.
What is home assistant using for auto-discovery? How can I adjust either my docker-compose or nginx config to allow the necessary data to passthrough?
My docker-compose is:
version: '3'
services:
  homeassistant:
    container_name: homeassistant
    image: "ghcr.io/home-assistant/home-assistant:stable"
    ports:
      - "8123:8123"
    volumes:
      - ./config:/config
      - /etc/localtime:/etc/localtime:ro
      - /run/dbus:/run/dbus:ro
    restart: unless-stopped
    network_mode: host
    cap_add:
      - NET_ADMIN
      - NET_RAW
    environment:
      - TZ: America/Los_Angeles
      - DISABLE_JEMALLOC: true
      - VIRTUAL_HOST=homeassist.voh.haus
      - VIRTUAL_PORT=8123
And my nginx configuration is:
server {
    server_name homeassist.voh.haus; # Replace with your chosen domain/hostname
    listen 80;
    # Optional: Redirect root URL to the /admin interface
    location / {
        proxy_pass http://127.0.0.1:8123; # Use container IP/hostname and internal port 80
        proxy_redirect off;
        proxy_set_header Host $host;
        proxy_set_header X-Real-IP $remote_addr;
        proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
        proxy_set_header X-Forwarded-Proto $scheme;
        proxy_set_header Upgrade $http_upgrade;
        proxy_set_header Connection "upgrade";
server {
    listen 8123;
    location / {
        proxy_pass http://127.0.0.1:8123; # Use container IP/hostname and inter>
        proxy_redirect off;
I broke out the listening so I could secure each separately with different methods in the future.
Do you need 80?
MDNS. Everything is using mdns for discovery and other connectivity checks over network.
Also, did you set x_Forwarded_for and trusted_proxies. Generally needed so HA can see ip of client device instead of all coming from proxy ip
