Pass through layout parameter to have panel layout styling for card
Invalidate cache for entities, devices, areas, labels, floors when config registry changes.
Load card / else via hui-card
card_as_row config to work as nested row in entities card
Always show card preview (or else card if configured)
Button updates
Filter editor issues where rules may be cleared in various scenarios
Ha tabs
Fixup rule count in filter editor
Migrate mwc-button to ha-button for HA 2025.8 mwc-button removal
Split translated states to own filter ‘state_translated’
Update workaround for cards which show errors
Performance improvements
This fork will be actively maintained and contrubutions are welcomed. If anyone is willing to translate the lengthy readme to MkDocs then please reach out.
To use this fork with HACS, set https://github.com/Lint-Free-Technology/lovelace-auto-entities as a custom HACS repository. Use the button above to do this in one step. The fork description starts with 💡 Lint Free Technology fork 💡 so you will easily see the correct HACS entry to use.
Thank you to @thomasloven for a great card and support for the Home Assistant community across many years.
Will check on this. I have tested a lot and have not come up with this before.
UPDATE: @KennethLavrsen repo updated to include a topic and image in readme which HACS requires for validation. Also added direct HACS button for custom repo in the original post to make this easy.
UPDATE 2: I did some further reveiw and the original error you presented suggests you tried to add as intergration rather than dashboard, hence the error. The validation errors I noted and fixed above are non fatal for validation.
As a silly question, but if this is improved code and such … why not push to originl owner … or take the project. What would anyone want two different ones and SWEAT bigtime to switch them.
2.0.0 is the evolution of 1.16.1-dcapslock.x versions that I have made available over time, the last being 1.16.1-dcapslock.11 before switching to 2.0.0. The fork build CI uses semantic-release now so much easier get patches out quickly.
