🔹 Auto-entities - Automatically fill cards with entities
Testing in developer tools shows the first returns an array, the second does not. So for second you could try…
  {% for state in states.input_datetime %}
     {{ {'entity': state.entity_id, 'type': "button" } }},
  {% endfor %}
template-entity-row actions are templatable, but you need to return an object for the main action config, being tap_action for what you are after. See doco for more.
I do not recall this option in multiple-entity-row.
As well as
Perhaps you confused multiple-entity-row with a template-entity-row?
Thanks everyone, I got it working now.
This was one problem.
This was the other problem.
so 2 of the sweetest new features in A-E beta currently, ignore_case in rename, and advanced state filter allowing an operator and entity_id:
  - type: custom:auto-entities
    show_empty: false
    card:
      type: entities
      uix:
        style: |
          .card-content {
            max-height: 200px;
            overflow-y: scroll;
      state_color: true
    filter:
      include:
        - label: batterij
          state:
            operator: "<"
            entity_id: input_number.battery_alert_level
#       template: >
#         {%- set alert_level = states('input_number.battery_alert_level')|int %}
#         {%- set ns = namespace(batt_low=[]) %}
#         {%- for s in label_entities('batterij')
#           if is_number(states(s)) and states(s)|int < alert_level
#           and has_value(s) %}
#         {%- set ns.batt_low = ns.batt_low + [s] %}
#         {%- endfor %}
#         {{ns.batt_low}}
    sort:
      method: state
      numeric: true
    rename:
      method: friendly_name
      find:
        - " Batterij"
        - " Battery"
        - " level"
      trim: true
      ingore_case: true
thx Darryn for implementing this!
Can you tell me how to make a list of unavailable devices? Not entities, but devices. If a device is completely unavailable, its entities are also unavailable.
{% set ns = namespace(devices=[]) %}
{% for entity in states if entity.state == 'unavailable' %}
  {% set device = device_attr(entity.entity_id, 'name') %}
  {% if device and device not in ns.devices %}
    {% set ns.devices = ns.devices + [device] %}
  {% endif %}
{% endfor %}
{{ ns.devices | count }}
In a template sensor, that would be something like:
template:
  - sensor:
      - name: Unavailable Devices
        unique_id: unavailable_devices
        icon: mdi:lan-disconnect
        state: >
            states
            | selectattr('state', 'eq', 'unavailable')
            | map(attribute='entity_id')
            | map('device_name')
            | reject('equalto', none)
            | unique
            | list
            | count
        attributes:
          devices: >
              states
              | map('device_name')
              | unique
              | sort
              | list
Thank you. I created a template sensor and it started displaying the devices. Could you please fully share the card to display this custom:auto-entities
I do not use auto-entities myself, so no clue about that.
I can't display a list of devices. If I create a regular sensor to display an attribute as the main property, it complains about the length of the status text.
Dear colleagues, the issue of removing unavailable devices remains open. I am unable to implement this.
You can definitely solve this with the info you have. The auto entities card support templates. Otherwise, display this in a markdown card: remove the count, sort and add newlines.
States are limited to 255 characters. You can put this in an attribute though (and make the state e.g. the count).
