I have multiple zwave controllers. So if I understand terminology:
The integration is “zwave”, of which I have three instances (call them zwave2, zwave3, zwave4 and I have literally renamed them as such).
From the documentation on auto-entities I can select by the generic integration zwave, but is it possible to select based on the instance name, e.g. zwave2. Something like this does NOT work I get nothing.
- type: custom:auto-entities
show_empty: false
card:
type: entities
title: ZWave2 RSSI
filter:
include:
- integration: "zwave2"
entity_id: "*rssi*"
options:
secondary_info: last-changed
Actually I haven’t figured out a integration name that works alone to get them all (and the documentation says it may not always work for integration due to HA limitations without being specific).
Is there a way to match on this thing I’m calling an instance of an integration (does it have a proper Home Assistant name)?
These span (and overlap)_areas so that doesn’t work. I guess I could give each device a label and try to use that but I was saving labels in case they had a better use than this edge case.
