@itsteddyyo thanks for you reply! i made it!!!
Heya, no that is not possible as a dashboard strategy needs to be the one creating the dashboard itself
Only view strategies can be inserted in views.
But the area-dashboard-strategy has a config option āextraViewsā and with that you could pass your existing views to the dashboard ![]()
Like this:
strategy:
type: custom:area-dashboard-strategy
config:
...other options
extraViews:
- ...your views
- strategy: #just an example
type: custom:battery-view-strategy
icon: mdi:test
path: test
title: Test
Thank you for clarifying the views.
Going back to sorting the areas, I see we can create labels sort:1, sort:2, etc. and the dashboard populates accordingly. In my demo environment, i added the sort labels to get it to be in alphabetical order.
If we have many areas, however, how would you recommend sorting it in alphabetical order and maintaining it when we add areas in the future.
Ex: GYM (sort:1) POOL (sort:2)
Future add BAR (sort:1) ?
Additionally, is it possible to sort by floors?
You would need to change the labels assigned to each area
I think thatĀ“s an okay compromise as that probably wonāt happen too much ![]()
If you only want to sort alphabetically just wait a little. Iām currently working on a big refactor that would among other things allow that. Thereās gonna be a few breaking changes but im pretty pleased with the new design and many caveats and impossibilities of v1 will be improved and the whole configuration will hopefully be more user-friendly ![]()
Currently there is no support for floors but if you want you can open a feature request (Open Feature Request) and describe how you think the solution should look like ![]()
That sounds great, looking forward to it! Thank you again for the feedback.
Release 2.0.0 Incoming!
Version 2.0 is finally here! This update brings a complete redesign of the configuration API, along with many exciting new features.
Why the Redesign?
The old configuration API just wasnāt cutting itāit made customization harder than it should be. Too often, I found myself saying, āThat doesnāt workā or āYeah, that complicated workaround is the only option.ā So, I knew it was time for a changeāand here it is! ![]()
Breaking Changes Alert!
Since this is a major overhaul, there are breaking changes. To make your transition smoother, check out the migration guide:
Migration Guide
Whatās New?
Aside from the breaking changes, thereās plenty to be excited about!
New Features
- Grid Sorting: You can now sort items within grids - see area-dashboard-strategy/grid-view-strategy
- Enhanced Navigation: Navigation in the Area Dashboard now supports all grid features - see area-dashboard-strategy
- Simplified Global Configuration: A new global config reduces overall setup complexity - see area-dashboard-strategy/grid-view-strategy
- Grid Editing: Modify grids using grid overrides and
gridMergeStrategy- see area-dashboard-strategy/grid-view-strategy - New Customizations per Grid: You can now set
replaceand width on each grid individually - see area-dashboard-strategy/grid-view-strategy - Value-Type Floor: Added capability to filter or sort by floor - see area-dashboard-strategy/grid-view-strategy
- Improved Error Messages: Error messages are now more descriptive and helpful.
Bug Fixes
- card_mod Fix: The card_mod functionality should work properly in grids.
- Multiple
$entityReplacement Issue: Fixed issues with multiple uses of$entity. - Several minor enhancements have been made.
Ready to upgrade? Check out the Migration Guide and enjoy the new features! Let me know if you have any questions or run into issues.
Happy configuring! ![]()
Hey!
Great work on the newest version.
One question I have:
If I set āposition: 1ā for a grid, it will always show up below the default grids, right? (since they are 0 by default).
Will I need to override all their positions?
Maybe it might make more sense for the default to be higher than 0?
I also cant seem to get extraviews to work atm.
I tried this (to replace the battery view):
extraViews:
- strategy: null
type: custom:grid-view-strategy
config:
global:
card:
type: custom:mini-graph-card
entities:
- $entity
filter:
include:
- type: domain
value: sensor
- type: attribute
config:
key: device_class
value: battery
grids:
- id: other
title: Others
filter:
include:
- type: domain
value: sensor
- type: attribute
config:
key: device_class
value: battery
It always automatically adds the ānullā after the strategy part.
And the view stays empty.
Heya, thanks! I really appreciate it! ![]()
Yes, it should always appear after them if the position is greater than 0.
If you donāt set a position or set it to 0, it will simply follow the order of the array, meaning it will also be at the bottom.
If you want it to appear before, you can set the position to a negative value (e.g., -1, -2, -3). The lower the number, the higher it will appear in the grid. ![]()
Your formatting seems to be incorrect - you need to specify type and config under strategy, not next to it:
- strategy:
config:
global:
Did I get that wrong somewhere in the documentation? If so, Iām really sorry! Just let me know, and Iāll fix it.
It was a lot of YAML, so maybe one slipped through. ![]()
I was not aware negative numbers were possible with the position.
And I dont think you got it wrong. I tried quite a few things with the extra view and probably got it wrong at some point during trying to get it working. ![]()
Thanks again. I quite like most changes.
Iām a novice at dashboard designing, this sure helps a lot to get somewhat organized. Thanks for creating this.
Is there anyway to have an Extra View tab go directly to another existing dashboard when you click on it?
Extra Views are just regular Home Assistant views, so I donāt think thereās any way to make them behave like that. But you can use a card that lets you add a navigation action - like the basic button card (but there are many more) - right in your existing view.
type: button
icon: mdi:chevron-right-circle-outline
show_name: false
show_icon: true
tap_action:
action: navigate
navigation_path: /otherdashboard
Thatāll take you to another dashboard when you tap the button ![]()
Yeah I figured that was the case. I had setup top cards which do work, but I do like the buttons on the top.
Newbie here!!
Iām trying to intergrate Eufy Security with this but the entities the dashboard adds for the cameras dont work without webrtc controls. how do i replace them witht the below so i have the control to turn them on, otherwise they are static images.
type: custom:webrtc-camera
entity: camera.upstairs
poster: image.upstairs_event_image_event_image
ui: true
shortcuts:
- name: Play
icon: mdi:play
service: camera.turn_on
service_data:
entity_id: camera.upstairs - name: Stop
icon: mdi:stop
service: camera.turn_off
service_data:
Hey, for that you could use the grid overwrite feature to overwrite the existing row for cameras: Configuration | Strategy Pack
The current camera row is described here in the config: strategy-pack/src/config/areaDefaultConfig.yaml at 7cd904b9473ac5f5aeb38073dfb196668c242515 Ā· itsteddyyo/strategy-pack Ā· GitHub
Edit: forgot to link the FAQ Entry: FAQ | Strategy Pack
