Is the firmware entity of the device enabled and set to visible?
yeah, by default, the update entity is disabled for some (or maybe all) devices. Enable that, and it should work normally.
im stupid!
this is the solution!
thanks a lot!!!
A small limitation in the automation.
If some devices are offline/unavailable at the time the automation was triggered, those devices wont get updated.
This happenrd to me. Two of my devices were offline when the automation was triggered, they came online after a minute. But i had to manually update them.
How to fix the automation for such a case ?
Iâve had a few instances where the ESPhome upgrade has broken the existing configuration and required it to be refactored.
Iâd personally say that unless there is a specific reason to upgrade your ESPhome devices to the latest version, I would simply leave them on whatever their current version is.
Hi all,
I created an automation that automatically updates ESPHome devices after an ESPHome addon/app update. It can optionally send progress notifications so you can monitor the update process, and it will provide a list of devices that failed to update at the end.
You only need to replace <YOUR PHONE> with the mobile device that should receive the notifications.
alias: ESPHome Update Checker
description: >-
Automatically update ESPHome Devices after ESPHome upgrade, and notify when
they are updated.
triggers:
- trigger: template
value_template: |
{{ integration_entities('esphome')
| select('match', '^update.')
| select('is_state', 'on')
| list | count > 0 }}
conditions:
- alias: Confirm something needs to be updated still
condition: template
value_template: |
{{ states.update
| selectattr('entity_id','in', integration_entities('esphome'))
| selectattr('state','eq','on')
| list | count > 0 }}
actions:
- variables:
failed: []
esphome_updates: |
{{ states.update
| map(attribute='entity_id')
| list }}
total_updates: "{{ esphome_updates | count }}"
updated: 0
- data:
action: notify.mobile_app_<YOUR PHONE>
title: ESPHome Devices update
message: >-
{% set entity = esphome_updates[0] %}
Updating {{ total_updates }} ESPHome device(s).
First device will now be updated from {{
state_attr(entity,'installed_version') }} to {{
state_attr(entity,'latest_version') }}.
- alias: Update all ESPHome devices in sequence
repeat:
for_each: "{{ esphome_updates }}"
sequence:
- action: notify.mobile_app_<YOUR PHONE>
message: |-
Updating {{ state_attr(repeat.item,'friendly_name') }}
({{ repeat.index }} / {{ total_updates }})
{{ total_updates - repeat.index }} devices remaining
tag: esphome_update
- action: update.install
entity_id: "{{ repeat.item }}"
data: {}
enabled: true
continue_on_error: true
- wait_template: "{{ state_attr(repeat.item, 'in_progress') == false }}"
continue_on_timeout: true
timeout: "00:1:00"
- wait_template: |-
{{ state_attr(repeat.item,'installed_version') is not none
and state_attr(repeat.item,'latest_version') is not none
and state_attr(repeat.item,'installed_version')
== state_attr(repeat.item,'latest_version') }}
timeout: "00:00:30"
- if:
- condition: template
value_template: >-
{{ state_attr(repeat.item,'installed_version') !=
then:
- variables:
failed: "{{ failed + [repeat.item] }}"
- action: notify.mobile_app_hessel_s_flurkje
message: >
Update failed for {{ state_attr(repeat.item, 'friendly_name')
}}. Please check the ESPHome addon.
else:
- variables:
updated: "{{ updated + 1 }}"
message: |-
{% if failed | count == 0 %}
All ESPHome devices are successfully updated to {{ state_attr(entity,'latest_version') }}.({{ updated }} / {{ total_updates }})
{% else %}
Updates finished, updated ({{ updated }} / {{ total_updates }}) to {{ state_attr(entity,'latest_version') }}
Failed: {{ failed | map('state_attr', 'friendly_name') | list | join(', ') }}
{% endif %}
tag: esphome_update
mode: single
Hi, for some reason this part will not save:
- data:
- action: notify.mobile_app_iphone
message: >-
state_attr(entity,âinstalled_versionâ) }} to {{
state_attr(entity,âlatest_versionâ) }}.
Could you please share your full yaml? I wanna understand the context where this data: is, as I wasnât expecting the action inside there.
So I've set up the automation via blue print
Getting some errors:
Logger: homeassistant.components.template.trigger
Source: components/template/trigger.py:63
Integration: Template (documentation, issues)
First occurred: 2:17:42 PM (1 occurrence)
Last logged: 2:17:42 PM
1st error:
Error initializing 'template' trigger for 'ESPHome Device Auto Bulk Update': UndefinedError: 'update_threshold' is undefined
2nd error:
Logger: homeassistant.helpers.event
Source: helpers/template/init.py:360
Error while processing template: Template<template=({{ expand(integration_entities('esphome')) | selectattr("entity_id", "contains", "update") | selectattr("state", "eq", "on") | list | count > update_threshold }}) renders=5348>
File "/usr/src/homeassistant/homeassistant/helpers/template/init.py", line 358, in async_render
render_result = render_with_context(self.template, compiled, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template/context.py", line 45, in render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.14/site-packages/jinja2/environment.py", line 1295, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.14/site-packages/jinja2/environment.py", line 942, in handle_exception
raise rewrite_traceback_stack(source=source)
File "", line 4, in top-level template code
jinja2.exceptions.UndefinedError: 'update_threshold' is undefined
File "/usr/src/homeassistant/homeassistant/helpers/template/init.py", line 476, in async_render_to_info
render_info._result = self.async_render( # noqa: SLF001
variables, strict=strict, log_fn=log_fn, **kwargs
File "/usr/src/homeassistant/homeassistant/helpers/template/init.py", line 360, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: UndefinedError: 'update_threshold' is undefined
3rd error:
Source: components/template/trigger.py:79
First occurred: 2:17:43 PM (1 occurrence)
Last logged: 2:17:43 PM
Error evaluating 'template' trigger for 'ESPHome Device Auto Bulk Update': UndefinedError: 'update_threshold' is undefined
This is most likely due to changes over time with Home Assistant.
Could you please review your blueprint with the latest HAOS, Core, Frontend
Thank you
Do you mean my blueprint? I don't think I use update_threshold on any recent version.
If so, could you please try to update the blueprint and try it again?
Sorry, I've tagged the wrong ESPHome update script/blueprint. Yours works fine at the moment. Still in the process of finding one with more options that checking, updating, notification (messaging cell phones) which seems to be limited due to only 3 messaging platforms to be supported currently, none of which I use or trust. Wish Google Messaging was supported/listed.
Message to HA companion app should be available now with Home Assistant latest version (from today).
Thank you just added that to your script along with a delay (time) to allow completion of the script to update all the devices.
