" autoautomation"
created this automation to help me create other automations, sensors, generating data from the sensor,etc. It uses ai_tasks. So, everywhere you just need to change the instructions and wait a moment and the answer will appear on the side panel
alias: autoautomatizace
description: ""
triggers:
  - trigger: state
    entity_id:
      - input_button.ai_task   #if you create a helper, otherwise run directly
    to: null                             #in automation, top right corner three dots
conditions: []
actions:
  - action: ai_task.generate_data
    metadata: {}
      task_name: yourname
      instructions: >+
      your data
    entity_id: ai_task.your_ai_task
    response_variable: airesponse
  - action: notify.persistent_notification
    metadata: {}
      message: "{{ airesponse.data }}"
        "[object Object]": null
