I would like to automate my garage door with an ESP8266, Home Assitant and MQTT. I found some code in a french tuto and I modified it a bit tuto ESP8266 + DHT22 + MQTT…. It really helps me to understand how MQTT is working. For now my ESP8266 is connected to a LED but I will change it with a power relay afterwards.
But I have a problem, if my ESP8266 is well connecting to the WiFi and to MOSQUITTO server (installed from HA “add-on store”), when I click on the button, some time the LED is turning ON/OFF sometime not… I need to click several time to succeed to do the action requested.
I made a mistake somewhere but I cannot figure out where is it. I think that maybe because the ESP8266 is not listening all the time the broker.
Thanks is advance for your help.
Lionel
Projet d'apprentissage d'un objet connecté (IoT) pour réaliser une sonde de température
ESP8266 + DHT22 + LED + MQTT + Home-Assistant
Projets DIY (https://www.projetsdiy.fr) - Mai 2016
Licence : MIT
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#define wifi_ssid "**********"
#define wifi_password "**************"
#define mqtt_server "192.168.1.199"
#define mqtt_user "**************" //s'il a été configuré sur Mosquitto
#define mqtt_password "******************" //idem
//Buffer qui permet de décoder les messages MQTT reçus
char message_buff[100];
long lastMsg = 0; //Horodatage du dernier message publié sur MQTT
long lastRecu = 0;
bool debug = false; //Affiche sur la console si True
WiFiClient espClient;
PubSubClient client(espClient);
void setup() {
Serial.begin(9600); //Facultatif pour le debug
pinMode(D2,OUTPUT); //Pin 2
setup_wifi(); //On se connecte au réseau wifi
client.setServer(mqtt_server, 1883); //Configuration de la connexion au serveur MQTT
client.setCallback(callback); //La fonction de callback qui est executée à chaque réception de message
//Connexion au réseau WiFi
void setup_wifi() {
delay(10);
Serial.println();
Serial.print("Connexion a ");
Serial.println(wifi_ssid);
WiFi.begin(wifi_ssid, wifi_password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("Connexion WiFi etablie ");
Serial.print("=> Addresse IP : ");
Serial.print(WiFi.localIP());
//Reconnexion
void reconnect() {
//Boucle jusqu'à obtenur une reconnexion
while (!client.connected()) {
Serial.print("Connexion au serveur MQTT...");
if (client.connect("ESP8266Client", mqtt_user, mqtt_password)) {
Serial.println("OK");
client.subscribe("homeassistant/switch1");
} else {
Serial.print("KO, erreur : ");
Serial.print(client.state());
Serial.println(" On attend 5 secondes avant de recommencer");
delay(5000);
void loop() {
if (!client.connected()) {
reconnect();
client.loop();
long now = millis();
if (now - lastRecu > 100 ) {
lastRecu = now;
void callback(char* topic, byte* payload, unsigned int length) {
int i = 0;
if ( debug ) {
Serial.println("Message recu => topic: " + String(topic));
Serial.print(" | longueur: " + String(length,DEC));
// create character buffer with ending null terminator (string)
for(i=0; i<length; i++) {
message_buff[i] = payload[i];
message_buff[i] = '\0';
String msgString = String(message_buff);
if ( debug ) {
Serial.println("Payload: " + msgString);
if ( msgString == "ON" ) {
digitalWrite(D2,HIGH);
} else {
digitalWrite(D2,LOW);
Here it is what I added to configuration.yaml :
mqtt:
broker: 192.168.1.199
port: 1883
client_id: home-assistant-1
keepalive: 60
username: ************* #optionnel
password: *********** #optionnel
protocol: 3.1 #par défaut
switch:
platform: mqtt
command_topic: "homeassistant/switch1" #Topic sur lequel on publie l'état de l'interrupteur
payload_on: "ON" # A vous de choisir le message envoyé lorsque l'interrupteur est allumé
payload_off: "OFF" # et éteint
optimistic: true # Mettez à true pour maintenir l'état
qos: 0
retain: true
value_template: '{{ value.x }}'
