Try to trigger the automation from the service panel
Ok, so I used the trigger. It ran, but thereās no sound. I can play the file directly on the webā¦
# TEST BLOCK for Fajr Adhan
- alias: TEST BLOCK Fujr Adhan
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_fajr"), "%Y-%m-%dT%H:%M:%S")) +1140 }}'
- service: media_player.volume_set
entity_id: media_player.office_speaker
volume_level: '0.7'
- service: media_extractor.play_media
media_content_id: http://hassio.local:8123/local/adhan_fajr_makkah.mp3
media_content_type: audio/mp3
- delay: '00:03:50' # time it takes to finish playing your adhan_fajr_makkah.mp3
media_content_id: http://hassio.local:8123/local/dua-e-adhan.mp3
audio files:
Asalam u Alaikum All,
is anyone here from Toronto area, I am not very technical and i am looking for some in-person help to set this automatic azaan for my home
Thanks & Regards
What media player speaker you use?? Sonos or what?
what is it you need help with?
google home mini; but its not the speakers, iāve tested it with the tutorial that msahar posted and it works fine.The issue is only when i add the delay and the local files you told me toā¦ it doesnāt work.
Jazakallah Brother, i just found the guide from msahar
I will try to follow that guide and if needed i will get back to you.
btw can you suggest the best place to buy PI board or starter kit ?? Thanks
What you can do is to call a script that call the mp3 files or try to make 2 automatines, one that trigger the other, or you can combine 2 mp3 file in 1 files and this way play only the combined mp3 file, I didnāt try they, but I could test later with my Google home.
im 100% convinced that its not the speaker issue. Its either the code or the audio file, im starting to doubt that the mp3 file is not readible by the app (media_player) which is called by hass.io
Try convert to .wav
ok so its not the audio file as well, Iām stumped now.
volume_level: '0.7'
media_content_id: http://hassio.local:8123/local/adhan_fajr_makkah.wav
#media_content_id: https://www.islamcan.com/audio/adhan/azan2.mp3
media_content_type: 'music'
- delay: '00:03:06' # time it takes to finish playing your adhan_fajr_makkah.mp3
media_content_id: http://hassio.local:8123/local/dua-e-adhan.wav
Try this
# Seperate Automation for Fajr Adhan
- alias: Fajr Adhan
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_fajr"), "%Y-%m-%dT%H:%M:%S")) +960 }}'
entity_id: media_player.hall_speaker
volume_level: '0.7'
- service: media_player.play_media
data_template:
media_content_type: 'audio/mp3'
- delay: '00:02:05'
data_template:
media_content_id: http://hassio.local:8123/local/adhan_duaa.mp3
just make sure you have access to your mp3 files through the URL.
so it triggers the speaker but nothing plays; i feel that the way this is coded is a problem?
Iāve updated it so that it reaches those files, triggers the speaker (i hear bleep) but thatās it.
# TEST BLOCK
- alias: TEST BLOCK Fajr Adhan
volume_level: '0.7'
data_template:
- delay: '00:03:50'
data_template:
media_content_id: http://khurram.org/aud/dua-e-adhan.mp3
UPDATE:
I think i have found the culprit but not sure what the solution is:
this address when played on on the browser, works: http://hassio.local:8123/local/adhan_fajr_makkah.mp3
but when i put that address in the code it doesnāt:
or
http://localhost:8123/local/adhan_fajr_makkah.mp3
Iāve put the audio on the internal server on a local ip address and it works fine
weird! but i guess we can let this one go cause it could just be my internal network playing games.
data_template:
I tried to run this portion in service console and worked fine for me , i used google chrom cast.
I also created this automation and from service trigger it and worked fine, try instead of using hassio.local, use the ip address of your pi, like http://192.168.7.10:8123/local/adan.mp3
Hey Hassan, Thanks for your assistance so far. Iāve come across another interesting issue, im not sure if this is a limitation or not, but I can only play 2 files per triggerā¦
so lets say im playing adhan and then the dua after itā¦ it wont go past that.
They should work try the url in a browser and see if you have access and it runs, if so it should work, make sure you have the delays well measured.
These work for me with a goole home mini:
# Play Adhan
- alias: Play Adhan
- entity_id: input_boolean.adhan
platform: state
to: 'on'
condition: []
entity_id: media_player.living_room_speaker
media_content_id: http://10.10.10.12:8123/local/adhan-main.mp3
media_content_type: music
- delay: '00:00:10'
- service: input_boolean.turn_off
- service: notify.ios_all
message: 'It is {{ states.sensor.salah_actual.state }} time, please perform wudhu.'
# Play Adhan Fajr
- alias: Play Adhan Fajr
- entity_id: input_boolean.adhan_fajr
platform: state
to: 'on'
condition: []
media_content_id: http://10.10.10.12:8123/local/adhan-fajr.mp3
- delay: '00:00:10'
