Automate Let's Encrypt Certificate Renewals
I tried to make it as simple as possible. The following automation triggers 30 days before a the HA certificate expires. It renews the certificate and restarts HA that evening at 3am.
It relies on the “Let’s Encrypt” add-on and the “Cert Expiry” integration being installed.
Replace ‘sensor.my_certificate_name_cert_expiry’ with your “Cert Expiry” sensor name.
Replace ‘notify.mobile_app_my_app’ with the name of your mobile app.
alias: Renew certificate before expiry
description: ""
triggers:
  - trigger: time
    at:
      entity_id: sensor.my_certificate_name_cert_expiry
      offset: "-720:00:00"
conditions: []
actions:
  - action: notify.mobile_app_my_app
    metadata: {}
      message: >-
        Going to renew my.certificate.name certificate tonight, will expire {{
        states('sensor.my_certificate_name_cert_expiry') }}
  - wait_for_trigger:
      - trigger: time
        at: "03:00:00"
    continue_on_timeout: false
    enabled: true
  - action: hassio.addon_start
      addon: core_letsencrypt
    enabled: true
  - delay:
      hours: 0
      minutes: 10
      seconds: 0
      milliseconds: 0
    enabled: true
  - action: homeassistant.restart
    metadata: {}
    data: {}
    enabled: true
    metadata: {}
      message: >-
        Renewed my.certificate.name certificate, will expire {{
  - action: notify.persistent_notification
    metadata: {}
      message: >-
mode: single
Sorry for being late to the party, but I’m really curious: what’s the advantage of your snippet over the one @luckman212 linked to above?
I’m not sure if you’re asking me or the post just above yours, but in either case, this comment applies (unless the site linked has been updated):
@The00Dustin I meant @whereisaaron, sorry for any inconvenience caused. :see_no_evil:
His script already calls restart instead of reboot, so it boils down to what’s the actual difference between the two? :sweat_smile:
Not a lot of difference as far as I can see. Just a simple automation instead of the blueprint maybe?
Here is a simple automation to renew the CERT if it expires in less then 24 hours.
alias: "Renew LE certificate"
description: "Renew SSL cert if less than 24 hours remaining"
mode: single
triggers:
  - trigger: time
    at: "03:15:00"
conditions:
  - condition: template
    value_template: >-
        (as_timestamp(states('sensor.<YOURFQDN>_cert_expiry'), default=0)
        - now().timestamp()) < 86400
actions:
  - action: hassio.addon_restart
  - delay:
      minutes: 2
      addon: core_nginx_proxy
Would it not be possible to reduce that down to “restart nginx proxy addon”, I suppose not everyone is using the certificate with that, but for those that are it would be less interruptive to restart the nginx addon only as HA would keep on running while nginx restarted.
A reload of nginx would be even better but I don’t think that is possible with addons, correct me if I’m wrong.
I see that ADN is already doing restart nginx proxy as well, appologies.
actions:
