This is my log:
日志记录器: aiohttp.server
来源: /usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py:451
首次出现: 15:33:27 (11 次总计出现)
上次记录: 15:36:06
Error handling request from 192.168.8.252
Error handling request from 192.168.8.1
File “/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py”, line 480, in _handle_request
resp = await request_handler(request)
File “/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py”, line 569, in _handle
return await handler(request)
File “/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py”, line 117, in impl
File “/usr/src/homeassistant/homeassistant/components/http/security_filter.py”, line 92, in security_filter_middleware
File “/usr/src/homeassistant/homeassistant/components/http/forwarded.py”, line 83, in forwarded_middleware
File “/usr/src/homeassistant/homeassistant/components/http/request_context.py”, line 26, in request_context_middleware
File “/usr/src/homeassistant/homeassistant/components/http/ban.py”, line 86, in ban_middleware
File “/usr/src/homeassistant/homeassistant/components/http/auth.py”, line 242, in auth_middleware
File “/usr/src/homeassistant/homeassistant/components/http/headers.py”, line 32, in headers_middleware
response = await handler(request)
File “/usr/src/homeassistant/homeassistant/helpers/http.py”, line 73, in handle
result = await handler(request, **request.match_info)
File “/usr/src/homeassistant/homeassistant/components/http/decorators.py”, line 81, in with_admin
return await func(self, request, *args, **kwargs)
File “/usr/src/homeassistant/homeassistant/components/config/view.py”, line 134, in post
await hass.async_add_executor_job(_write, path, current)
File “/usr/local/lib/python3.13/concurrent/futures/thread.py”, line 59, in run
File “/usr/src/homeassistant/homeassistant/components/config/view.py”, line 251, in _write
write_utf8_file_atomic(path, contents)
File “/usr/src/homeassistant/homeassistant/util/file.py”, line 39, in write_utf8_file_atomic
fdesc.write(utf8_data)
UnicodeEncodeError: ‘ascii’ codec can’t encode characters in position 31-35: ordinal not in range(128)
