Automatic Backup Power automation not working as expected
I am making an esp32 device that does multiple functions controlling backup power with my network and home assistant, as well as a few security controls. Some of the functions I am automating to work when the esp32 is not connected to home assistant.
I want the esp32 to start a script that makes sure 5 external devices are powered on when the esp32 detects grid power restored. The esp32 remains continuously powered by battery. The binary sensor, shore_power_detect, detects the grid power. The devices are powered on by switches named modem, mcp23008_pin_1, networkpi, mcp23008_pin_0, and ups_power. ups_power is a template switch that combines a binary sensor (ups_power_detect) and a switch (ups_cycle). ups_cycle is a switch that is automated to act like a momentary button mimicking the ups device factory button. It is hardwired (hacked) directly into the ups device and running parallel with and how the factory button is operated.
The “while:” automation with long delay is to basically de-bounce any erratic grid power as it comes back on.
Everything in the config works as expected except my automation in question. When I test the esp32 and watch the logger it, if the ups_power is already on, it then turns it off and on again to instead of remaining in the on state, thus hard shutting down anything plugged into the ups. I’m assuming this might be because turning on the template switch (ups_power) that is already in “on” state is bound to the automated ups_cycle.
It gets even weirder. The script then tries to run again, but can’t because its a single only. And when I turn the ups_ back on manually, it is automatically turned off after about a couple minute delay.
Here’s the config. The automation (bellow shore_power_detect) and script (bottom of config, turn_on_full_network) in question are commented out.
Thanks!
Blake
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
ethernet:
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO0_IN
  phy_addr: 1
  power_pin: GPIO16
i2c:
  sda: 5
  scl: 17
web_server:
  port: 10001
  ota: false
mcp23008:
  - id: 'mcp23008_hub'
    address: 0x20
################################# Outputs ############################################
switch:
  - platform: restart
    name: "Restart Top Mechroom Control Module"
  - platform: gpio
    pin: 12
    internal: True
    restore_mode: ALWAYS_OFF
    on_turn_on:
    - delay: 2000ms
    - switch.turn_off: ups_cycle
    lambda: |-
      if (id(ups_power_detect).state) {
        return true;
      } else {
        return false;
    turn_on_action:
      - switch.turn_on: ups_cycle
    turn_off_action:
  - platform: gpio
    pin: 4
    restore_mode: ALWAYS_On
    inverted: true
  - platform: gpio
    pin: 2
    inverted: true
    name: "Alarm Armed Switch"
    optimistic: True
    turn_off_action:
      - switch.turn_off: top_mechroom_strobe
########### Expansion Hub Power Mosfets ################
  - platform: gpio
    name: "Top Mechroom Siren"
    pin:
      mcp23xxx: mcp23008_hub
      number: 5
      mode:
        output: true
      inverted: false
    restore_mode: ALWAYS_off
  - platform: gpio
    internal: true
    pin:
      number: 4
      mode:
        output: true
      inverted: false
    name: "Top Mechroom Strobe"
    optimistic: true
    on_turn_on:
      - while:
          condition:
            switch.is_on: top_mechroom_strobe
          then:
          - switch.turn_on: mcp23008_pin_4
          - delay: 50ms
          - switch.turn_off: mcp23008_pin_4
          - delay: 175ms
    on_turn_off:
      - delay: 10ms
  - platform: gpio
    name: "Aux Output 12v"
    pin:
      number: 3
      mode:
        output: true
      inverted: true
  - platform: gpio
    name: "Odroid Home Assistant"
    pin:
      number: 0
      mode:
        output: true
      inverted: true
    restore_mode: ALWAYS_on
  - platform: gpio
    name: "Top Mechroom Router and Switch"
    pin:
      number: 1
      mode:
        output: true
      inverted: true
  - platform: gpio
    name: "Top Mechroom Sensor Module"
    pin:
      number: 2
      mode:
        output: true
      inverted: true
############# Expansion Hub Opto Switch #########################
  - platform: gpio
    pin:
      number: 7
      mode:
        output: true
      inverted: false
    restore_mode: ALWAYS_Off
    icon: "mdi:gate"
    on_turn_on:
    - delay: 500ms
    - switch.turn_off: gate_cycle
  - platform: gpio
    pin:
      number: 6
      mode:
        output: true
      inverted: false
############################## Buttons #################################################
button:
    name: "Restart Top Mechroom Router and Switch"
    on_press:
      then:
      - switch.turn_off: mcp23008_pin_1
      - delay: 10s
      - switch.turn_on: mcp23008_pin_1
    on_press:
      then:
      - switch.turn_off: modem
      - delay: 10s
      - switch.turn_on: modem
############################### Inputs ###############################################
binary_sensor:
  - platform: gpio
    pin:
      number: 36
      mode: input
      inverted: true
    name: "Shore Power Detect"
    device_class: power
#    on_press:
#      - while:
#          condition:
#            binary_sensor.is_on: shore_power_detect
#          then:
#          - delay: 240s
#          - switch.turn_off: inverter_power
#          - script.execute: turn_on_full_network
#    on_release:
#      then:
#         - switch.turn_on: inverter_power
  - platform: gpio
    pin:
      number: 32
      mode: input
      inverted: true
    name: "UPS Power Detect"
    filters:
      - delayed_off: 500ms # capacitor on pin further delays off
    device_class: power
  - platform: gpio
    pin:
      number: 33
      mode: input
      inverted: true
    filters:
      - delayed_off: 50ms
    on_press:
      then:
        - script.execute: cycle_gate_script
  - platform: gpio
    pin:
      number: 14
      mode: input
      inverted: true
    filters:
      - delayed_off: 50ms
    on_press:
      then:
        - switch.turn_off: alarm_armed_switch
  - platform: gpio
    pin:
      number: 39
      mode: input
      inverted: false
    name: "Top Mechroom Door"
    filters:
      - delayed_off: 50ms
    device_class: door
    on_press:
      if:
        condition:
          and:
            - switch.is_on: alarm_armed_switch
            - binary_sensor.is_off: top_mechroom_control_module_status
        then:
          - switch.turn_on: top_mechroom_strobe
    on_release:
      if:
        condition:
        then:
          - delay: 10s
  - platform: gpio
    pin:
      number: 15
      mode: input
      inverted: false
    filters:
      - delayed_off: 50ms
    device_class: door
    icon: "mdi:gate"
    name: "Alarm Armed Sensor"
    lambda: |-
      if (id(home_assistant_alarm_state).state == "armed_away" || id(home_assistant_alarm_state).state == "armed_home") {
        return true;
      } else {
        return false;
    on_press:
      then:
        - switch.turn_on: alarm_armed_switch
    on_release:
      then:
  - platform: status
    name: "Top Mechroom Control Module Status"
################ HA Sensors ######################
  - platform: homeassistant
    name: "Low Battery Shut Off Home Assistant"
    entity_id: input_boolean.low_battery_shutoff_ha
    on_press:
      then:
        - switch.turn_off: mcp23008_pin_0
        - delay: 30s
text_sensor:
    name: "Home Assistant Alarm state"
    entity_id: alarm_control_panel.alarm
    internal: True
################ Analog Sensor ###################
  - platform: adc
    pin: 35
    name: "Battery Bank Voltage"
    update_interval: 3s
    attenuation: 6db
    accuracy_decimals: 1
    filters:
    - offset: 0
    - multiply: 12
    - sliding_window_moving_average:
        window_size: 10
        send_every: 10
##################### scripts #####################
script:
  - id: cycle_gate_script
    then:
      - switch.turn_on: gate_cycle
      - delay: 2000ms
#  - id: turn_on_full_network
#    then:
#      - switch.turn_on: modem
#      - delay: 60s
#      - switch.turn_on: mcp23008_pin_1 # switch and router
#      - delay: 180s
#      - switch.turn_on: networkpi
#      - switch.turn_on: mcp23008_pin_0 # odroid
#      - switch.turn_on: ups_power
  - id: turn_on_ha_network
    then:
  - id: strobe
    then:
      - switch.turn_on: mcp23008_pin_3
      - delay: 100ms
      - switch.turn_off: mcp23008_pin_3
      - delay: 100ms
