I’m brand new here, so apologies in advance if my post isn’t complete.
I’m trying to use Home Assistant to automate a pump based on data from my solar power system.
I’ve already installed EcoFlow Cloud on Home Assistant and can see my smart plug there as an entity. What I’m missing is my PowerOcean and my storage unit.
I wrote the following script, but since the entities sensor.ecoflow-pv_power and sensor.ecoflow_soc cannot be found, the pump cannot be switched on automatically:
Blockquote
type: vertical-stack
cards:
- type: entities
title:
Pool control
show_header_toggle: false
entities:- entity: input_select.pool_pump_mode
name: Mode selection
icon: mdi:cog - entity: switch.pool_heat_pump
icon: mdi:water-pump
state_color: true
- type: glance
title:
Energy overview (EcoFlow)
entities:- entity: sensor.ecoflow_pv_power
icon: mdi:solar-power - entity: sensor.ecoflow_soc
icon: mdi:battery-high
- type: conditional
conditions:- entity: switch.pool_heat_pump
state_not: “off”
card:
type: markdown
content: |
The pool pump is currently running.
Making optimal use of available solar energy.
- type: conditional
Blockquote
Does anyone know how to solve this problem?
Thank you in advance.
