every time I go out of power, I’m no more able to log in into home assistant, and I need to restart it manually. I assume the cause (but I might be wrong) is that HA instance probably loads before the router.
Is there a way to set a delay in some config to wait a couple of minutes every time the HA gets an unexpected shut down?
Thanks.
What about a static IP?
unfortunately home assistant is already set up with static IP.
I need this as well, I can’t find any reboot options to add to scripts or automations, am I missing something?
