I have several cameras that monitor the house.
There is a card on the picture-entity dashboard in which you can view cameras.
But if you add all the cameras to the dashboard, it will take up a lot of space.
The card has fields:
type: picture-entity
entity: switch.okhrana
image: /local/coff.png
camera_image: camera.1_substream
I wanted to place an picture-entity card on the dashboard and change the source at certain intervals, for example 10 seconds.
Also, if the switch is turned off, the camera field is cleared and a static image is displayed on the card.
List of cameras:
- “camera.1_substream”,
- “camera.2_substream”,
- “camera.N_substream”
If the switch “entity: switch.okhrana” is enabled, then
- Take 1 camera from the list and substitute the value in the “camera_image” field:
- The timer counts down 10 seconds
- Take 2 camera from the list and substitute the value in the “camera_image” field:
camera_image: camera.2_substream
And so on until we reach the end of the list of cameras, after which we return to the first camera.
If the switch “entity: switch.okhrana” is disabled, then
- Clear the “camera_image” field and show a static image “image: /local/camera_off.png”
But I’m new to working with HA and have no idea how to do it.
This is generally possible to do in home assistant?
Perhaps I wrote unclearly, sorry, English is not my native language.
