Hello, I have Window AC/Heating unit that I have added to Home assistant using the Midea Integration.
I want to keep the room in a range of temperature so have tried making an automation that uses a separate external temperature sensor and turns on/off the AC and heating based on it.
It “works” but its too finicky, the unit will sometimes turn on for 5 seconds and then turn off, or vice versa. And sometimes it stays on for a long time, making the temperature go beyond what I want.
I use mainly Node-red for my automations, but im OK with using the integrated system in home assistant.
Does anyone have experience with something like this?
