Automation Action based on Input_select
Hi Guys,
I have a automation that’s triggers on motion sensor and i have a input_select to chose a scene name.
Can some help me with a action that will check the value of de input_select en triggers a scene. The scene names are not the same as the input_select options.
someting like
Action
If input_select is Normal scene.turn_on light_normal
If input_select is Dimd scene.turn_on light_Dimd
If input_select is off scene.turn_on light_of
Try this:
 - alias 'motion'
      platform: state
      entity_id: sensor.yourmotionsensorname
      to: 'on'
      service: scene.turn_on
      data_template:
        entity_id: >
           {% if is_state('input_select.scene', 'Normal') %}scene.light_normal
           {% elif is_state('input_select.scene', 'Dimmed') %}scene.light_dimd
           {% elif is_state('input_select.scene', 'Off') %}scene.light_off
           {% endif %}
