Automation - action/choose/condition/entity_id… only one and default?
I have two flood sensors and I am using two entity_ids for each sensor (alarm/ /burglar). The entity_ids friendly names are descriptive, so I do not need any more text in the notifications I send.
A generic automation for the two (ore more) sensor would be nice to accomplice.
One shortcoming is that you can only use one entity_id in a condition not several, or am I doing something wrong (this fails when executing while ok when Configuration validation)?
          - conditions:
              - condition: state
                entity_id: sensor.fibaro_flood_sensor_burglar_loft,
                           sensor.fibaro_flood_sensor_burglar_kitchen
                state: '3
when I only use one entity_id the automations work for this condition (WARNING), but also the default service (ALARM) notification is sent which it should not when burglar is triggered.
Any ideas?
  - alias: "Flood sensor Alarm"
    description: "Flood sensor Alarm - Flood/burglar (Kitchen/Loft)"
      - platform: state
        entity_id:
          - binary_sensor.fibaro_flood_sensor_loft
          - sensor.fibaro_flood_sensor_burglar_loft
          - binary_sensor.fibaro_flood_sensor_kitchen
          - sensor.fibaro_flood_sensor_burglar_kitchen
      - choose:
          - conditions:
              - condition: state
                entity_id: sensor.fibaro_flood_sensor_burglar_kitchen
                state: '3'
            sequence:
              - service: notify.me
                  title: 'HA - WARNING'
                  message: "{{ trigger.from_state.attributes.friendly_name }}"
        default:
              title: 'HA - ALARM!'
                push:
                  sound:
                    critical: 1
                    volume: 1.0
Try adding a second condition after the first condition instead of putting both sensors in the same condition.
That works, but that’s exatly what I am trying to avoid, since the logic is the same for the same kind of entidy_ids.
