I’ve been trying to work out an automation that will, dependent upon the amount of spare solar I have, switch multiple devices on or off so that I can consume as much spare solar as possible and limit export.
I have this so far which looks to run but not switch anything. I have no entity reference in the service section which i guess maybe the issue…? Not sure how to resolve it though. Any help appreciated.
If you find it challenging to understand the service documentation, one trick I use to figure out the needed yaml is to create a simple automation in the GUI editor and then review automations.yaml.
Your float conversions are wrong. Should be done thus (first line only, similarly for others):
{% if states('sensor.gridconsumption')|float(0) > 800 and states('sensor.gridconsumption')|float(0) < 1000 %}
The states() is a string and needs converting to int or float before comparison. Your original compares a string to 800 then a string to a float-converted 1000. These days, you should include a default value in the float filter, which is what the (0) is.
you can’t create multiple service calls like that within a template branch.
And there is no such service as “switch.kitchen_door_sockets_s1.turn_on”.
the service is “switch.turn_on” and then you reference the entity_id.
What I would do is use choose actions and set the conditions for each sequence as the branches in your template and the set the sequence to be syntactically correct service calls.
FWIW, I confirmed this technique works (tested with an input_number in place of the sensor and input_booleans instead of switches).
The value of id is handled like this:
Anything to the left of the space represents switches to be turned on.
Anything to the right of the space represents switches to be turned off.
none indicates there are no switches to be turned on or off.
Multiple switches, to be turned on or off, are separated by a comma.
id: 'switch.kitchen_door_sockets_s1 switch.x_office_door_sockets_s2'
ON | OFF
space
ON | ON | OFF
comma space
I assume you may already know this but, in case you don’t, I noticed the following behavior when testing the automation:
Assume that initially the value of sensor.gridconsumption is below 800 and both switches are off.
The moment the sensor’s value rises above and crosses the 800 watt threshold, the first switch is turned on.
Now let’s say the value decreases below 800 watts. The first switch is left on and not turned off. It won’t be turned off until the sensor’s value decreases below 0.
It’s a good point @123. And no its not. I have been thinking the same.
What I’ll need to do is store a property, somehow, against both switches (sockets) as the value of their consumption when on: i.e.
switch.kitchen_door_sockets_s2: 800 (Watts)
switch.x_office_door_sockets_s1: 1000 (Watts)
That or I put power monitors on each device…
This way I I can check the grid consumption and then check, if the switches are on, that the live grid consumption includes 800, 1000 or 1800 Watts.
Using your example:
‘sensor.gridconsumption’ = 750W.
‘sensor.spare_solar_devices_consumption’ = 0W.
‘sensor.corrected_consumption’ = 750W.
The moment the sensor’s value rises above and crosses the 800 watt threshold, the first switch is turned on @800W consumtpion
‘sensor.gridconsumption’ = ‘sensor.corrected_consumption’ - ‘sensor.spare_solar_devices_consumption’ = 750 - 800 = - 50W. The negative suggest you are now importing power form the grid!
if ‘sensor.corrected_consumption’ < ‘sensor.spare_solar_devices_consumption’ then turn OFF solar devices.
Does that make sense? It would take a couple more sensors being created but i think it could work…?!
I can’t answer your question because I don’t understand the underlying purpose of turning the switches on/off. It seems like a way of reducing overall power consumption based on thresholds of total power consumption. However, I’m not sure if that’s the actual goal.
