Automation Action to Set Value of Input Helper Based on Device Attribute
Long-time automation guy (but HA noob) stumped with the automation front-end for setting the value of an entity based on a device attribute. Is this even possible?Specifics:
I’m trying to set the value of either (preferably both, but I’ll take either):
(1) an input helper (number 0-100)
(2) a dimmer device
I’m using the automation front-end to define the action. But the trick is that I want to reference the value in a device attribute, not an entity. Is this possible? TIA…
What is the entity id and attribute name?
There are a few examples. But one of them is:
  • Entity ID for the dimmer device: [light.alice_tank_level] (that I want to assign the value to)
  • Device attribute: Tank Level (attribute I want to get the value from)
  • Device: Alice (it’s a Braava M6 mop)
Is there an ID for a device and/or device attribute? I realized I’ve given you the labels above.
Thanks for your reply.
Look in Developer Tools → States. Find the entity id of your mop.
OK I see the entity ID for the mop, but coming back to the original question, I still can’t figure out how to use an Action in the Automation front-end to set the value of an entity to the value of a device attribute. Assume I’m missing something.
EDIT: to be more clear, I can see how to set the value of a dimmer or a helper to a number (73, 42, 9, 57), but not to the value of a device attribute. Seems like such a basic action. Is it possible?
Yes - if you tell me the entity ids I can show you how.
The entityID for the mop is Vacuum.Alice. I don’t see an entity ID for the device attribute in question.
EDIT: But the attribute, as shown in States, is called tank_level
I doubt that. Entity ids do not contain capital letters.
Try this:
- service: light.turn_on
    entity_id: light.alice_tank_level
    brightness_pct: "{{ state_attr('vacuum.alice',tank_level')|int(0) }}"
This will not work correctly unless the tank level only has values from 0 to 100.
I did something using Z-Wave Devices and an input helper. Anytime I change the value of the input helper it triggers the automation and uses that value as input for the Z-Wave Set Value Service.
alias: GE Dimmer
description: ""
  - platform: state
    entity_id:
      - input_number.dimmer
condition: []
  - service: zwave_js.set_value
      device_id: fe45284459b650c9aa876a28c27021b2
      property: targetValue
      value: "{{ states('input_number.dimmer') }}"
      command_class: "38"
mode: single
Think it was just autocorrect at work, combined with my sloppiness — yes it’s vacuum.alice
Thank you. Will try. And yes valid values are 0-100 so I think I’m safe.
Can I correctly infer, by its absence, that there is no way to assign a value to an entity based on another entity just using an action in the automation front end (not YAML)? I’m not averse to YAML, just seeking to understand.
@tom_l Im guessing there’s a simple typo with the single quotes since there’s an odd number of them in the snippet you shared, but whatever I do (e.g., one pair or two pairs of single quotes), I get an error message. “expected dictionary @ data [‘action’][0]”
Pretty sure I’m doing something noobish.
Yeah there should be quotes both sides of the attribute ‘tank_level’, sorry.
brightness_pct: "{{ state_attr('vacuum.alice','tank_level')|int(0) }}"
Ok got it thx. Works now TYVM!
@tom_l, I assume there’s an analogue to this syntax for text strings, rather than dimmers. Is there documentation somewhere I can consult, rather than asking for you each individual scenario?
Templating has opened my eyes to entirely new possibilities. Thanks @tom_l !
Today, I’ve been trying to create a simple automation that stuffs a thermostat’s setpoint value into a number helper. I keep getting “expected float for dictionary value @ data[‘value’]. Got None”. I’ve scoured the forum to try to understand what to do, but I’m stumped.
I even pasted the template into the “Developer tools” template area, and it returns the expected value.
service: input_number.set_value
  entity_id: input_number.wh_master_setpoint
    value: {{ state_attr("climate.water_heater_master_local_water_heater_master_local","temperature") | int(0) }}
I’ve mindlessly replaced int with float, added/removed quotes and double quotes, all to no avail. Any ideas what I’m doing wrong?
https://www.home-assistant.io/docs/configuration/templating/#important-template-rules
value: "{{ state_attr('climate.water_heater_master_local_water_heater_master_local','temperature') }}"
Thanks for the link, Tom (and the fix, too)
