Automation Antifreeze Covers
Hi there,
I would like to implement an antifreeze-function for my covers.
If the temperature gets below 2 degrees and the Coverposition is higher than 80%, the cover has to drive up to 80%.
So this is, what I made:
alias: Frostschutz Rollos
description: ""
triggers:
  - trigger: numeric_state
    entity_id:
      - sensor.wetterstation_temperatur2
      - sensor.kwl_aussentemperatur
    below: 2
conditions: []
actions:
  - if:
      - condition: numeric_state
        entity_id: cover.eg_garderobe_rollo
        attribute: current_position
        above: 80
    then:
      - action: cover.set_cover_position
        metadata: {}
          position: 80
  - if:
        entity_id: cover.og_schlafzimmer_rollo
        above: 80
    then:
        metadata: {}
          position: 80
mode: single
Can someone help me, what is wrong?
Kind regards!
