Hey guys, I’m having a little issue with home assistant version 0.43 where all my automation script constantly turn themselves off and when that happen i have to re-enable them myself.
Have you checked the log to see what’s turning them off? I’m assuming that you don’t have a script or automation that’s turning them off.
Having the same issue. Since 0.43.0, didn’t happen before.
I did check for that, but i didn’t anything that doing it.
Can’t see anything in .43 that would be an obvious thing; can you give an example or two of the automations that are shutting themselves off? Maybe it might reveal something. You may also want to turn your log level up to info and see if you can catch something in the logs when you see the automations turn themselves off.
