I’m looking for a way to detect if a specific smartplug (and the device behind it) is no longer consuming energy, in this case a water heater.
I created an automation to trigger when the smartplug is activated and on the condition that the power is < 1W. But this isn’t functioning because the eventual power consumption is starting 1-2 seconds after the trigger.
I need an automation to detect if the smartplug is no longer consuming power within x seconds after each activation (relay on) of this smartplug, can someone help me?
It helps if you share your automation yaml, correctly formatted for the forum using the </> button in the post toolbar. But all it requires is your trigger for the switch to be on for 2 seconds before checking the power like this:
triggers:
- trigger: state
entity_id: switch.smart_plug
to: 'on'
for: 2 # this is the bit you need. wont trigger until the plug has been on for 2s
conditions:
- condition: numeric state
entity_id: sensor.smart_plug_power
below: 1
actions:
- action: etc...
