Automation based on Google calendar event with specific word in descriprion
Hi There!
Is it possible to create an automation that has as a trigger a Google Calenda event that contain a specific word in the description (that contains more then one word).
Example: I have an event where the description is something like: “Metting for testing my new config”.
I want that the trigger is based only on the presence of “meeting” in the description.
:slight_smile:
Thank you!
- cal_id: "*****@group.calendar.google.com"
  entities:
  - device_id: test_unimportant
    track: true
    search: "#UnImportant"
  - device_id: test_important
    track: true
    search: "#Important"
    offset: "!!"
Hi @ha_user22323,
Thank you! I will give it a try! :slight_smile:
Well i tried it.
But i’m doing something wrong and can’t find it.
So first off all, it’s working default.
I see my 3 calendars in my developers tools, i have my calender with all my events, so that’s ok.
my google_calender.yaml was ok.
When i added 3 events with a #tag then he didn’t imported them.
Ok, restart → not ok and he put automatic my default calender back at the bottom.
is there a syntax error, i’m really looking over it…
