Automation based on input_select problem
Hi all,
I’m trying to make that happen - automation based on input_select.
This my automation code:
- alias: spotify_minix
    platform: state
    entity_id: input_select.minix_spotify
    - service: script.turn_on
        entity_id_template: >
          {% if it is state("input_select.minix_spotify", "Electronic") %}
            script.spotify_minix_electronic
          {%-elif is_state("input_select.minix_spotify", "Regae") %}
            script.spotify_minix_regae
          {%-elif is_state("input_select.minix_spotify", "Rock") %}
            script.spotify_minix_rock
          {%-elif is_state("input_select.minix_spotify", "S") %}
            script.spotify_minix_s
          {%-elif is_state("input_select.minix_spotify", "Stop i wyłącz amplituner") %}
            script.spotify_minix_stop
          {% else %}
            none
          {% endif %}
I will be grateful for any help
Read the example here:
Under the heading : USE TEMPLATES TO DETERMINE THE ATTRIBUTES
Thanks, after that it should like to be:
    platform: state
      data_template:
        entity_id: >
          {% if is_state("input_select.minix_spotify", "Electronic") %}
          {% else %}
            none
          {% endif %}
It works! :slight_smile:
