Automation based on outside temp
So the thing i want to do is turn on switch.driveway_socket at different times based on the temperature outside
kinda like this
if temp outside between -1 to -10 turn on 06:00
if temp outside between -11 to -20 turn on 05:00
if temp outside between -21 to -30 turn on 04:00
if temp outside < -31 turn on 03:00
Times and temps are just examples but is this possible to achieve?
You can totally do this with an automation that has a template trigger.
Answering this spring in 27C sunshine and thinking ‘poor bastard’.
When is the conditional temp being measured. It could be different at 3am and 5am - your problem is not particularly well defined.
You can however create a series of automations to look at the outside temp at 3, then 4 then 5 etc.
However what happens if it is -28 at 3am then goes down to -32 at 3.30.
Things to ponder.
Hmm good question… i need an automation to check the temp like every 15 min… dunno if thats possible tho
Hmm thanks, will look into it
Will something like this worked? i really cant figure this out in my head, haha!
- id: '1572773700846'
  alias: 1 TEST
  description: ''
  - hours: ''
    minutes: /15
    platform: time_pattern
    seconds: ''
  condition:
  - condition: state
    entity_id: switch.driveway_socket
    state: 'off'
  - condition: and
    conditions:
    - below: '-1'
      condition: numeric_state
      entity_id: sensor.weather_temperature
    - condition: and
      conditions:
      - above: '-15'
    - after: 05:30:00
      condition: time
  - condition: or
    conditions:
    - below: '-16'
    - above: '-25'
    - after: 04:30:00
      condition: time
  - data:
    service: switch.turn_on
