Edit: In case anyone else runs into this problem, this is what works:
g_bright_mode:
sequence:
- service: light.turn_on
data_template:
entity_id: '{{ input_light }}'
brightness: 255
color_temp: 226
- alias: Lamp Bright
- platform: state
entity_id: input_select.lamp_mode
to: "Bright"
- service: script.g_bright_mode
input_light: 'light.lamp'
I’m very new to home assistant and need help understanding why this isn’t working.
I have this script:
g_bright_mode:
sequence:
brightness: 255
color_temp: 226
and this automation:
- platform: state
to: "Bright"
entity_id: light.lamp
I was hoping to set up multiple automations to set lights to bright mode (or other modes) individually. But the script always calls all lights, not just the one specified in the automation. I also tried:
- platform: state
to: "Bright"
Still didn’t work.
Is this a limitation of light.turn_on? Does the script have to have the entity_id of a specific light to make it work? Will I need to make a “Bright” script for each light instead?
