Automation: condition between sensor
Hello everybody.
In addition to the two sensors for sunrise and sunset, I have configured other 2 sensors always starting from sunrise and sunset and I have added the minutes set in a variable to optimize the time of switching on and off of a light.
    sensors:
      prossima_alba:
        entity_id: sun.sun
        friendly_name: 'Prossima alba'
        value_template: >
          {{ as_timestamp(states.sun.sun.attributes.next_rising) | timestamp_custom(' %H:%M') | replace(" 0", "") }}
        icon_template: mdi:weather-sunset-up
     prossimo_tramonto:
        entity_id: sun.sun
        friendly_name: 'Prossimo tramonto'
        value_template: >
          {{ as_timestamp(states.sun.sun.attributes.next_setting) | timestamp_custom(' %H:%M') | replace(" 0", "") }}
        icon_template: mdi:weather-sunset-down
      prossima_alba_calcolata:
        entity_id: sun.sun
        friendly_name: 'Prossima alba calcolata'
        value_template: >
          {% set correzione_alba = (states('input_number.minuti_correzione_alba'))  | int * 60 %}
          {% set alba = as_timestamp(state_attr('sun.sun','next_rising')) %}
          {{ (alba + correzione_alba) | timestamp_custom('%H:%M') }}
      prossimo_tramonto_calcolato:
        entity_id: sun.sun
        friendly_name: 'Prossimo tramonto calcolato'
        value_template: >
          {% set correzione_tramonto = (states('input_number.minuti_correzione_tramonto'))  | int * 60 %}
          {% set tramonto = as_timestamp(state_attr('sun.sun','next_setting')) %}
          {{ (tramonto + correzione_tramonto) | timestamp_custom('%H:%M') }}
This is the result in a lovelace card:
Alba_tramonto
Later I created a card to select the ignition mode: on, automatic, off
type: custom:mod-card
style: |
  ha-card {
    border: 1px solid black;
    background: white;
card:
  type: vertical-stack
  cards:
    - type: custom:button-card
      custom_fields:
        name_luce_dietro: Luce dietro
        icon_luce_dietro: |
          <ha-icon
            icon="mdi:lightbulb"
            style="width: 30px; height: 30px;">
          </ha-icon>
      styles:
        grid:
          - grid-template-columns: 1fr 30%
          - grid-template-rows: 1fr
          - grid-template-areas: '"name_luce_dietro icon_luce_dietro"'
        custom_fields:
          name_luce_dietro:
            - font-size: 20px
          icon_luce_dietro:
            - color: |-
                 if (states['switch.luce_porta_dietro'].state == "on")
                 return "yellow";
                 return "black";
    - type: horizontal-stack
      cards:
          entity: input_select.modalita_luce_dietro
          icon: mdi:lightbulb-on-outline
          tap_action:
            action: call-service
            service: input_select.select_option
            service_data:
              entity_id: input_select.modalita_luce_dietro
              option: sempre_acceso
          show_state: false
          show_name: false
          state:
            - value: sempre_acceso
              color: rgb(5, 147, 255)
          icon: mdi:calendar-clock
          tap_action:
            service_data:
              option: automatico
          show_state: false
          show_name: false
          state:
            - value: automatico
          icon: mdi:lightbulb-off-outline
          tap_action:
            service_data:
              option: sempre_spento
          show_state: false
          show_name: false
          state:
            - value: sempre_spento
Card
Finally I created an automation to manage the three states and when I select the automatic mode, I would like the light to switch on between sunset and sunrise (the ones I have optimized), but I don’t know how to do it. You can help me?
This is the automation where I should correct the “after” and “before” in the “automatico” state
- alias: modalita_accensione_luce_dietro
    platform: state
    - choose:
        - conditions:
            - condition: state
              state: "sempre_acceso"
          sequence:
            - service: switch.turn_on
              entity_id: switch.luce_porta_dietro
            - service: automation.turn_off
              entity_id: automation.accensione_automatica_luce_porta_dietro
        - conditions:
            - condition: state
              state: "sempre_spento"
          sequence:
            - service: switch.turn_off
        - conditions:
            - condition: state
              state: "automatico"
            - condition: time
              after: {{ sensor.prossimo_tramonto_calcolato }}
              before: {{ sensor.prossima_alba_calcolata }}
          sequence:
You are triggering from the state of your input_select only, so once in automatic mode, it won’t get triggered again. I think you need to trigger on:
  • changes to the mode
  • time of “optimised sunrise”
  • time of “optimised sunset”
With sensor.time installed (docs):
    - platform: state
      value_template: "{{ states('sensor.time') == states('sensor.prossima_alba_calcolata') }}"
      value_template: "{{ states('sensor.time') == states('sensor.prossima_tramonto_calcolata') }}"
and then build logic into your automatic action condition (docs) to determine what action to take based on the time. Like this:
        - conditions:
            - condition: state
              state: "automatico"
          sequence:
            - service: >-
                {% if states('sensor.prossima_alba_calcolata') <= states('sensor.time') < states('sensor.prossima_tramonto_calcolata') %}
                  switch.turn_off
                {% else %}
                  switch.turn_on
                {% endif %}
So if the mode is changed to automatic, or if it is one of your optimised times, the sequence will run, turning the light off if it is between sunrise and sunset, or on if it is not. Note I test for being between sunrise and sunset, as the simple test I use won’t work across midnight.
FYI, if you don’t the hour to be zero-padded, simply do this (instead of using replace(" 0", "") in the template):
{{ as_timestamp(states.sun.sun.attributes.next_rising) | timestamp_custom('%-H:%M') }}
The hyphen in %-H means you want the hour without zero-padding.
Fantastic, it works perfectly. Thank you very much
Thank you for your suggestion
