Automation, Condition, Pool Pump and Pool Heater
So I have a switch for my pool pump and a switch for my pool heater, connected to a temperature guage that measures water temperature.
What I need is an automation or something that will keep my pump running while the heater is on. I have an example below of what I think I should be doing, but it doesn’t seem to work.
The issue is I use a timer from Tasmota, just in case there is a disconnect to HA the pump will still run everyday.
switch.01_nodemcu_1 (This is the Heater)
switch.02_nodemcu_3 (This is the Pump)
–What I need is a way for my pump to be activated if the heater is activated (the first automation acheives this), but if tasmota says turn off pump and the heater is still running at that time, I would like HA to overide this and instantly turn the pump back on.–
Any suggestions?
- id: main_pump_with_heater
  alias: "Turn On Pool Pump With Heater"
    platform: state
    entity_id: switch.01_nodemcu_1
    to: 'on'
    service: switch.turn_on
    entity_id: switch.02_nodemcu_3
    platform: state
    to: 'on'
  condition:
    condition: state
    state: 'off'
the hookup has a really good hack of this (youtube) you should check out his videos
Figured it out!!!
Does this look ok? seems to work great
    platform: state
    to: 'on'
- id: main_pump_keep_on_heater
  alias: "Keep On Pool Pump With Heater"
    platform: state
    to: 'off'
  condition:
    condition: state
    state: 'on'
