Automation Config Failing
HI All,
I have the below config trying to trigger a push bullet notification on a sensor change. For some reason it seems to always show an error on restart.
Any idea what I am doing wrong?
Error Message:
Invalid config
The following components and platforms could not be set up:
** automation**
Please check your config.
This is in my automation.yaml file.
#              System Automations                  #
#        Ring Front Door Motion Automation         #
alias: "Front door motion sensor"
  platform: state
  to: 'off'
  entity_id: binary_sensor.sensor
  service: notify.mobile-notification
    title: 'Hello there.'
    message: 'Testing 12345'
What does the log say that should point to a line number
I can’t find any reference to any error in the logs. That’s why I am stumpted
Since the error is about setting up automation I expect a problem in you config.yaml. Can you post the part of the config you link the automation.yaml?
I found the issues.
Even though I set the notify service name like this
The actual service name in the services was
notify.mobilenotification
Wierd, but it works now.
