G’day I have an automation that occasionally errors but works on the second attempt.
Because of this error it stops the automation and won’t execute the condition to see if it failed…
I setup continue_on_error but it still isn’t proceeding… any tips?
This is the Bluetooth Proxy configuration
esp32doit-devkit-v1
by Espressif
Firmware: 2024.7.3 (Aug 29 2024, 16:29:54)
Sir_Goodenough
((SG) WhatAreWeFixing.Today)
February 26, 2025, 12:40am
2
Hello Anton2079 ,
It is going to be a bit harder to diagnose if we can’t share your code.
Please post the YAML version and use the </> button in the editor to display it properly.
How to help us help you - or How to ask a good question .
Here is the YAML
The error comes from this section
- device_id: cb0c8c3bca1294b599b05f4ef0f341c7
domain: select
entity_id: 9b73b21ae8830689c14cda922207689a
type: select_option
option: Manual
continue_on_error: true
All of the YAML is below
alias: Pool Morning
description: ""
triggers:
- trigger: state
entity_id:
- input_select.home_state
to: Daytime
for:
hours: 0
minutes: 0
seconds: 0
conditions: []
actions:
- if:
- condition: or
conditions:
- condition: numeric_state
entity_id: sensor.my_home_percentage_charged
above: 19
entity_id: sensor.my_home_solar_power
above: 2.5
then: []
else:
- wait_for_trigger:
- trigger: numeric_state
entity_id:
- sensor.my_home_percentage_charged
above: 19
entity_id:
- sensor.my_home_solar_power
above: 2.5
timeout:
hours: 1
minutes: 30
seconds: 0
milliseconds: 0
domain: select
type: select_option
option: Manual
- delay:
hours: 0
minutes: 2
seconds: 0
milliseconds: 0
- if:
- condition: state
entity_id: binary_sensor.pool_pump_status
state: "on"
then: []
else:
domain: select
type: select_option
option: Manual
- delay:
hours: 0
minutes: 2
seconds: 0
milliseconds: 0
- if:
- condition: state
state: "on"
then: []
else:
- action: notify.mobile_app_xxxxxx_iphone
metadata: {}
message: Failure pool
title: xxxxxx
- delay:
hours: 1
minutes: 28
seconds: 0
milliseconds: 0
domain: select
type: select_option
option: "Off"
- delay:
hours: 0
minutes: 2
seconds: 0
milliseconds: 0
- if:
- condition: state
state: "off"
then: []
else:
- if:
- condition: state
state: "off"
then: []
else:
metadata: {}
message: Failure pool stop
title: xxxxxxx
- delay:
hours: 0
minutes: 2
seconds: 0
milliseconds: 0
domain: select
type: select_option
option: "Off"
mode: single
