Automation - Diabetes triggers for Medtronic
As a person with two people who have diabetes at home ( wife and son), both using the Medtronic pump and Carelink app ( which has been disconnected from the Carelink integration with the new security patch). I have had to find a solution to trigger home warnings of any dangerous situation that might occur due to diabetes ( high sugar levels and more importantly low sugar).
My previous Solution:
  • Using the Carelink integration to get info via Carelink, showed every detail needed to have accurate management ( sensor expiry, connection loss, low battery pump or sensor, high sugar, low sugar…etc ) and based on that accurate triggers to accurate automation and actions based on each case.
    Unfortunately due to Medtronic’s change in its security protocols, the connection was not possible anymore unless there was a way to bypass the security check.
My current solution was :
  • Last notification and last removed notifications from Android phones that are connected to the diabetes devices ( sensor and pump) via the home assistant app.
    Unfortunately, the notifications from the Android aren’t always up-to-date and more accurate I have to base it on both last and last remove notifications as triggers additionally the triggers are limited to keywords that are found in those notifications based on a value template trigger.
My testing solution I am currently doing:
  • On any phone ( the current Android phone), install Xdrip+ connect via Carelink to get the information and upload it to a private server that has Nightscout, then use the Nightscout integration to upload Glucose levels to trigger anything.
    Unfortunately, I haven’t been able to get any other value pushed from Nightscout to the Nightscout integration in Home Assistant with the only value provided being blood glucose.
If anyone wants to work on this together, be my guest. here is the code for the current solution:
( the actions → telegram message + google speakers voice notifications)
( triggers → NightScout Glucose level + Last notification + last removed notifications)
alias: "Diabetes: Yousef Sensor "
description: Diabetes Update via Android Notifications Lists and last removed Notifications
    value_template: >-
      {{ 'glucose approaching Low' in
      states('sensor.medtronic_pixel_last_notification') }}
    alias: Approaching Low
  - alias: Enter Blood Glucose
    platform: template
    value_template: >-
      {{ 'Enter BG to continue in SmartGuard.' in
    value_template: >-
      {{ 'High sensor glucose' in
    alias: High Blood Glucose
    value_template: >-
      {{ 'Glucose was 250 mg/dL or higher' in
    alias: Very High Blood Glucose
    value_template: "{{ 'Uknown' in states('sensor.medtronic_pixel_last_notification') }}"
    alias: Not Connected
    value_template: >-
      {{ 'change the infusion set' in
    alias: Time to Change Infusion Set
    value_template: >-
      {{ 'Change reservoir' in
    alias: 10.0 units remaining. Change reservoir
  - alias: Approaching Low
    platform: template
    value_template: >-
      states('sensor.medtronic_pixel_last_removed_notification') }}
    platform: template
    value_template: >-
      {{ 'Enter BG to continue in SmartGuard' in
  - alias: High Blood Glucose
    platform: template
    value_template: >-
  - alias: Very High Blood Glucose
    platform: template
    value_template: >-
  - alias: Not Connected
    platform: template
    value_template: >-
      {{ 'Uknown' in states('sensor.medtronic_pixel_last_removed_notification')
  - alias: Time to Change Infusion Set
    platform: template
    value_template: >-
  - alias: 10.0 units remaining. Change reservoir
    platform: template
    value_template: >-
  - platform: numeric_state
    entity_id: sensor.blood_sugar
    for:
      hours: 0
      minutes: 5
      seconds: 0
    above: 200
    below: 299
    alias: Blood Glucose Above 200 and below 299
  - alias: Blood Glucose under 85
    for:
      hours: 0
      minutes: 5
      seconds: 0
    below: 85
  - alias: Blood Glucose Above 300+
    for:
      hours: 0
      minutes: 5
      seconds: 0
    above: 300
  - alias: Loss of Connection
    platform: template
    value_template: >-
      {{ 'transmitter and sensor connection is secure' in
    platform: template
    value_template: >-
  - alias: Low Sugar
    platform: template
    value_template: >-
      {{ 'changed to Low sensor glucose' in
  - alias: Low Sugar
    platform: template
    value_template: >-
  - alias: Send outbound message based on inbound trigger message
    choose:
      - conditions:
          - condition: trigger
            id:
              - lowsugar
        sequence:
          - data:
              volume_level: 1
            service: media_player.volume_set
              entity_id: media_player.all
          - delay:
              hours: 0
              minutes: 0
              seconds: 3
              milliseconds: 0
          - service: tts.google_say
              message: Yousef is Approaching Low, Please Check on him!
              cache: true
          - delay:
              hours: 0
              minutes: 0
              seconds: 10
              milliseconds: 0
          - data:
              volume_level: 0.8
          - service: notify.everyone
              title: Approaching Low!
      - conditions:
            id:
              - test
        sequence:
          - data:
              volume_level: 1
          - delay:
              hours: 0
              minutes: 0
              seconds: 3
              milliseconds: 0
              message: >-
                Yousef Needs to Enter Blood Glucose to continue in SmartGuard.
                Please Test Him!
              cache: true
          - delay:
              hours: 0
              minutes: 0
              seconds: 10
              milliseconds: 0
          - data:
              volume_level: 0.8
              message: >-
                Please Test Him!
              title: Test Blood Glucose
      - conditions:
            id:
              - highbg
        sequence:
          - data:
              volume_level: 1
          - delay:
              hours: 0
              minutes: 0
              seconds: 3
              milliseconds: 0
              message: Yousef is High on Glucose sensor. Please check Blood Glucose!
              cache: true
          - delay:
              hours: 0
              minutes: 0
              seconds: 10
              milliseconds: 0
          - data:
              volume_level: 0.8
              title: Yousef High!
      - conditions:
            id:
              - vhighbg
        sequence:
          - data:
              volume_level: 1
          - delay:
              hours: 0
              minutes: 0
              seconds: 3
              milliseconds: 0
              message: >-
                Yousefs Sugar Level was 250 mg/dL or higher for more than 3
                hours.  Please Check Pump Infusion Set!
              cache: true
          - delay:
              hours: 0
              minutes: 0
              seconds: 10
              milliseconds: 0
          - data:
              volume_level: 0.8
              message: >-
              title: Yousef Very HIGH!
      - conditions:
            id:
              - notconnected
          - condition: time
            after: "21:00:00"
            before: "08:00:00"
        sequence:
          - data:
              volume_level: 1
          - delay:
              hours: 0
              minutes: 0
              seconds: 3
              milliseconds: 0
              message: >-
                Yousefs Pump and Sensor arent connected to the Phone Please
                Check on Him
              cache: true
          - delay:
              hours: 0
              minutes: 0
              seconds: 10
              milliseconds: 0
          - data:
              volume_level: 0.8
              message: >-
                Check on Him
              title: No Connection at BedTime!
      - conditions:
            id:
              - infusionset
        sequence:
          - data:
              volume_level: 1
          - delay:
              hours: 0
              minutes: 0
              seconds: 3
              milliseconds: 0
              message: >-
                Its been three days since the last infusion set change for
                Yousef. Time to change the infusion set!
              cache: true
          - delay:
              hours: 0
              minutes: 0
              seconds: 10
              milliseconds: 0
          - data:
              volume_level: 0.8
              message: >-
                Yousef. Time to change the infusion set.
              title: Change Infusion Set!
      - conditions:
            id:
              - lowresvoir
        sequence:
          - data:
              volume_level: 1
          - delay:
              hours: 0
              minutes: 0
              seconds: 3
              milliseconds: 0
              message: >-
                The amount of insulin in yousefs pump is low, please change the
                resvior!
              cache: true
          - delay:
              hours: 0
              minutes: 0
              seconds: 10
              milliseconds: 0
          - data:
              volume_level: 0.8
              message: >-
                resvior!
      - conditions:
            id:
              - vlowsugar
        sequence:
          - data:
              volume_level: 1
          - delay:
              hours: 0
              minutes: 0
              seconds: 3
              milliseconds: 0
              message: Yousef is Low, please check on him URGENTLY!
              cache: true
          - delay:
              hours: 0
              minutes: 0
              seconds: 10
              milliseconds: 0
          - data:
              volume_level: 0.8
              message: Yousef is Low! please check on him NOW!
              title: Yousef is Low!
      - conditions:
            id:
              - sensorconnect
        sequence:
          - data:
              volume_level: 1
          - delay:
              hours: 0
              minutes: 0
              seconds: 3
              milliseconds: 0
              message: >-
                Ensure transmitter and sensor connection is secure, Check your
                pump.!
              cache: true
          - delay:
              hours: 0
              minutes: 0
              seconds: 10
              milliseconds: 0
          - data:
              volume_level: 0.8
              message: >-
                pump.
              title: Transmitter and sensor connection
    enabled: true
mode: single
I’ll post later. I use the nightscout api to get some info.
The new plugin work perfect… Download firefox and plugin just to do this… save the install files for later even… it uses a auth token so it is working like the carelink follower app… you should also download the carelink follower app on your phone and make a user account (This is just so Carelink expects constant interaction with their API’s). Do the steps on GitHub - ondrej1024/carelink-python-client: Experimental Medtronic CareLink Client in Python and if you did it right you should have the carelink integration running exactly like the old one…
Just noticed… After you get firefox and the plugin then login to carelink while your in the plugin, instead of saving it to file, copy the actual token code in the box then paste it into home assistant’s “add integration” wizard… then you are done…
