Hello, I tried to create an automation to start my dishwasher.
The goal is to send the start command when there is sufficient PV generation.
The automation worked perfectly the first time. However, from the second day on, nothing happens anymore.
I also noticed that the two entity IDs — input_boolean.trigger_geschirrspuler_bereits_gelaufen and input_boolean.geschirrspuler_kann_starten — are not being set accordingly.
Can anyone help me?
alias: Geschirrspüler_starten
description: ""
triggers:
- trigger: state
entity_id:
- automation.geschirrspuler_startbereit
- "off"
to:
- "on"
conditions: []
actions:
- if:
- condition: and
conditions:
- condition: time
after: "06:00:00"
before: "14:00:00"
weekday:
- mon
- tue
- wed
- thu
- fri
- sat
- sun
- condition: state
entity_id: input_boolean.trigger_geschirrspuler_bereits_gelaufen
state:
- "off"
- type: is_not_open
condition: device
device_id: xxx
entity_id: xxx
domain: binary_sensor
- condition: numeric_state
entity_id: sensor.pv_power_in_watt
above: 2000
then:
- type: turn_on
device_id: xxxx
entity_id: xxx
domain: switch
- delay:
hours: 0
minutes: 0
seconds: 10
milliseconds: 0
- device_id: xxx
domain: select
entity_id: xxxx
type: select_first
- delay:
hours: 0
minutes: 0
seconds: 10
milliseconds: 0
- device_id: xxxxx
domain: button
entity_id: axxxxx
type: press
- action: input_boolean.turn_on
metadata: {}
data: {}
- action: input_boolean.turn_off
metadata: {}
data: {}
entity_id: input_boolean.geschirrspuler_kann_starten
else:
- delay:
hours: 0
minutes: 10
seconds: 0
milliseconds: 0
- action: automation.turn_on
metadata: {}
data: {}
entity_id: automation.geschirrspuler_starten
mode: single
