Automation doesn't work anymore after an upgrade
After an upgrade from HA 0.84 to 0.88 the following automation doesn’t work anymore but I cannot find out why. Can someone with more knowledge/experience help me please to identify the problem?
#Schlummern
  - id: schlummern_on
    alias: "Schlummern einschalten"
      platform: state
      entity_id: timer.schlummern
      to: 'active'
      service: media_player.volume_mute
        entity_id: media_player.schlafzimmer
        is_volume_muted: yes
  - id: schlummern_off
    alias: "Schlummern ausschalten"
      platform: event
      event_type: timer.finished
      event_data:
        entity_id: 'timer.schlummern'
        is_volume_muted: no
# Radiowecker
  - id: radiowecker_werktags
    alias: "Radiowecker werktags"
      - platform: time
        minutes: '/1'
        seconds: 0
    condition:
      - condition: state
        entity_id: input_boolean.alarmweekon
        state: 'on'
      - condition: state
        entity_id: input_boolean.alarmweekday
        state: 'on'
      - condition: time
        weekday:
          - mon
          - tue
          - wed
          - thu
          - fri
      - condition: template
        value_template: '{{ now().strftime("%H:%M") == states.sensor.alarm_time.state }}'
      - service: media_player.volume_set
        data_template:
          volume_level: 0.1
      - service: tts.google_say
        data_template:
          message: Guten Morgen. Es ist {{now().hour}} Uhr {{now().minute}}
          cache: false
      - delay: 00:00:15
      - service: media_player.play_media
        data_template:
          entity_id: media_player.wecker
          media_content_id: 'http://fluxfm.hoerradar.de/fluxfmberlin-live-aac-mq?sABC=59s45n23%230%23no8617362n29q2o435p17n54928n16s5%23gharva&amsparams=playerid:tunein;skey:1509186083'
          media_content_type: 'audio/mp3'
  - id: radiowecker_wochenende
    alias: "Radiowecker am Wochenende"
      - platform: time
        minutes: '/1'
        seconds: 0
    condition:
      - condition: state
        state: 'on'
      - condition: state
        state: 'off'
      - condition: time
        weekday:
          - sat
          - sun
        data_template:
          volume_level: 0.1
        data_template:
          cache: false
      - delay: 00:00:15
        data_template:
It’s platform: time
it should be time_pattern
the one with the weekday: should not be time_pattern btw
I would also recommend to add
initial_state: true
to your automations, to make sure they are on when you restart your system. See example
And another thing; Your wakeup automations are spamming your system. You run these automations every minute. I wouldn’t do that. Add the time sensor and change the trigger to match the wakeup time to the time sensor
Thanks for the quick reply and support.
I have the wakeups in the automation so that I can change the alarm time dynamically with sliders in the frontend. Don’t know how I could use the time sensor instead.
I changed the automatisations now to this:
#Schlummern
  - id: schlummern_on
    initial_state: true
      platform: state
      to: 'active'
    initial_state: true
      platform: event
      event_data:
        is_volume_muted: no
# Radiowecker
    initial_state: true
      - platform: time_pattern
        minutes: '/1'
        seconds: 0
    condition:
      - condition: state
        state: 'on'
      - condition: state
        state: 'on'
      - condition: time
        weekday:
          - mon
          - tue
          - wed
          - thu
          - fri
        data_template:
          volume_level: 0.1
        data_template:
          cache: false
      - delay: 00:00:15
        data_template:
    initial_state: true
        minutes: '/1'
        seconds: 0
    condition:
      - condition: state
        state: 'on'
      - condition: state
        state: 'off'
      - condition: time
        weekday:
          - sat
          - sun
        data_template:
          volume_level: 0.1
        data_template:
          cache: false
      - delay: 00:00:15
        data_template:
you mean something like:
      platform: template
      value_template: >
        {{ states('sensor.time') ==
          (state_attr('input_datetime.sleeptime','timestamp') | int | timestamp_custom('%H:%M', False)) }}
or to make it use a wake-timer:
  platform: template
  value_template: >
    {{ states('sensor.time') == states('sensor.alarmclock_we_time_template') }}
I wonder if that would make any significant difference for the spamming as you call it, since it would still trigger every minute?
Yes, that’s what i mean. First of all; it’s a better practice (cleaner code). Secondly it doens’t check the conditions every minute. Only checks the trigger every minute. With one automation it should affect the system much, but with a couple it could slow everything down.
Does it work now? Does HA trow any errors?
suppose you’re right, let’s see what happens:
automation:
  - alias: Alarm Clock
    initial_state: 'on'
      -  platform: template
         value_template: >
         value_template: >
           {{ states('sensor.time') == states('sensor.alarmclock_wd_time_template') }}
#      platform: time
#      minutes: '/1'
#      seconds: 00
    condition:
      condition: or
      conditions:
        - condition: and
          conditions:
#          - condition: template
#            value_template: >
#              {{ now().time().strftime("%H:%M") ==
#                states('sensor.alarmclock_wd_time_template')}}
            value_template: >
              {{ is_state('input_boolean.alarmclock_wd_enabled','on')}}
            value_template: >
              {{ is_state('binary_sensor.workday_sensor','on')}}
        - condition: and
          conditions:
#            value_template: >
#                 states('sensor.alarmclock_we_time_template')}}
            value_template: >
              {{ is_state('input_boolean.alarmclock_we_enabled','on')}}
            value_template: >
              {{ is_state('binary_sensor.workday_sensor','off')}}
      service: script.alarmclock_ring
update
confirmed: this works just fine, hope to see some extra % taken off the processor-usage :wink:
