hello to everyone, after updating to HASS 0.58.1 the automation editor does not work. I can change existing ones but I can not create new ones. I’m going for the script editor.
I noticed this yesterday also on my docker container. Not good.
I also installed it in Docker!
I just installed the 0.59. Let’s see if they fixed it.
now I’m out of the house, so I can not try it! Do you know if they have solved it?
Doesn’t look like it.
Now I may have a another issue but well documented, that you need the id: field in each action. So when I go to rebuild them, I can’t change the trigger option from state to sun. It doesn’t change the editable fields. It stays on the state fields.
maybe we have different problems! my existing automations work well and I can also modify them! If I create a new one through the editor, it does not let me do it. For example, if I click on the trigger button to add a new trigger, nothing happens!
I was getting the same thing also. I tried to create a new automation and couldn’t even save it.
Idem at me
Looks like someone else opened a issue report on github for hassio.
then it’s a version bug! We wait for him to solve it then!
I’m having issues manually adding new automations to the yaml file.
When I reload HA the new automation doesnt appear in the development section.
