All my automations appear on the Automations tab. However, when I click on an automation, the screen is blank. I’m running a Chrome browser. If I try to add a new automation, I see the editor. Any suggestions?
On first few times it was blank to me too… but today I see them. Maybe Chrome has some strange cache going on? Idk…
but then, even if you see the editor… it’s not prime time for use yet… lots of my automation has conditions and none of them are supported… even time trigger isn’t supported… so until then, it’s not much useful
I can see my automations, but i cannt edit anything since all “triggers” are showing “Not supported”, I’ve tried it on both my hassbian environment and my hass.io docker environment, same issue on both (docker enviroment completely empty so it’s using the standard configuration for HA 0.45.1)
We’re at 47.1 and the annotation editor is still not working for me with Chrome. I can create new annotations but I can’t edit existing annotations. Any suggestions?
I’m at 0.48 and the automation editor is still not working in Chrome. All my automations are in one file and I’ve preceded each automatic using a unique id.
Does this work for anyone! Any help would be appreciated.
for me, it was as simple as using the right name for the automations.yaml file. I had this file from before, but it was called automation.yaml, not automations.yaml. this was apparently enough to display the automations, but not being able to edit them - very intuitive…
