Automation editor using multiple entities
With all this gui help to make things missing I feel like I’m missing something. In the script/automation editor it says to go ahead and select multiple entities. I have to switch to yaml mode or type it in manually. Just a stupid question I guess but sometimes somebody shows you what that ‘insert whatever control’ on ‘insert whatever device’ here and your like wow oh thats what that does lol
I have same question. If I define multiple entities I get warning. The automation editor says that: Name(s) of entities to turn off. I assume that it should be possible to select multiple entities right from there.
manually type to match
Also it’s an old topic, but I guess you have to add the target and it should be:
service: switch.turn_off
data: {}
  entity_id:
    - switch.business_neon_1
    - switch.business_neon_2
