Automation error help
I’ve just added an automation and keep getting the below error when checking config but can’t figure out why. I’ve commented out each condition separately but still get the error:
Error Log:
Logger: homeassistant.config
Source: config.py:457
First occurred: 10:10:06 AM (14 occurrences)
Last logged: 10:27:17 AM
Invalid config for [automation]: expected str for dictionary value @ data['condition'][0]['conditions'][3]['state']. Got None. (See /config/configuration.yaml, line 67).
Invalid config for [automation]: [entity_id] is an invalid option for [automation]. Check: automation->entity_id. (See /config/configuration.yaml, line 67).
Automation:
- alias: Front Door Light Activate Expected
  mode: single
    platform: time
    entity_id:
    at: '17:00:00'
  condition:
    condition: and
    conditions:
    - condition: state
      entity_id: person.rachel
      state: 'Work'
    - condition: time
      weekday:
      - mon
      - tue
      - wed
      - thu
      - fri
      - sun
    - condition: numeric_state
      entity_id: sun.sun
      attribute: elevation
      below: -0.4
    - condition: state
      entity_id: light.front_door_light
      state: 'off'
  - service: script.front_door_illuminate
Delete the line entity_id:
The time platform accepts no entity_id
Does light.front_door_light exist?
Thank you.
Removing entity_id: from the trigger seems to have worked. Don’t know why I didn’t spot that.
Yes, the entity light.front_door_light does exist.
Then I can’t explain why there should be a state error.
