Automation Error: trigger: In 'numeric_state' condition: no entity specified
My goal is to trigger this automation when the radon reading is above 2.
The Log shows:
  • Error in ‘Radon Fan Start above x (A.X.)’ trigger: In ‘numeric_state’ condition: no entity specified
sensor.crawlspace_radon_pciperliter is a helper which scales the value for a unit of measure different from the sensor’s default UOM. I see it as an entity in the Developer Tools > States list and the state is numeric as expected.
I think I’ve coded the trigger correctly, so why the error?
Thx!
- id: 69a933c2-6fa6-4b9d-873d-f5ff8d6764ef2
  alias: Radon Fan Start above x (A.X.)
    - platform: numeric_state
      entity_id: sensor.crawlspace_radon_pciperliter
      above: 2 # triggers when crossing from below this value
  condition:
    - condition: state
      entity_id: switch.radon_fan
      state: "off"
    - service: switch.turn_on
      data: {}
    - service: switch.turn_off
        entity_id: switch.crawl_dehumidifier
      data: {}
    - service: notify.mobile_app_bucks_iphone
        message: (A.X.) Crawl radon above threshold
        title: "HA: Energized the radon fan, de-energized the dehumidifier"
Does that text to the right of above: 2 exist in your actual automation or did you just add that for the example posted above?
EDIT
Never mind. For some reason I thought inline YAML comments weren’t supported. :roll_eyes:
Right, and just to confirm, same error using this syntax:
      entity_id:
        - sensor.crawlspace_radon_pciperliter
