I’m trying to see if there is a ‘not’ in the conditions - I cannot see it but I may just have missed it.
Basically I want an automation to take an action except between certain a certain time in the day so not during that period of time (and specific days).
I’m sure it is obvious but I can’t see how to do it or find a relevant example.
All I can think is to do an or for firing the action between 00:00 to 12:00 OR 14:00 to 23:59. Is that the best solution?
the before and after is in relation to midnight (00:00:00).
So “before: 14:30:00” means from midnght to 14:30:00. “after: 16:00:00” means after 16:00:00 but before midnight. so the way you have it it will only fire from midnight to 14:30 or 16:00 till midnight.
If you had the before and after reversed it it would run from 14:30 to 16:00 since the “before: 16:00” is limited by the “after: 14:30” and the “after: 14:30” is limited on the other end by the “before: 16:00”.
