MarcoAT31
(Marco At31)
February 10, 2025, 1:22pm
1
Hello community,
I tried to create a new automation, which is also my first one, but every time I try to save it, I get the following message:
here are my Yaml config:
automation: include automations.yaml
alias: Vorhaus Eingang Bewegungsmelder ausschalten
triggers:
platform: state
entity_id: light.sdomoticabticino8
to: ‘on’
for:
hours: 0
minutes: 0
seconds: 10
conditions:
actions:
service: light.turn_off
mode: single
alias: Neue Automation
triggers:
platform: device
device_id: 133b4f2c3549c7499c39036fbc619f40
domain: media_player
entity_id: media_player.c2653e13ec752ca57d93b3abee770af4
type: turned_on
conditions:
actions:
service: cover.close_cover
entity_id: cover.sdomoticabticino38
mode: single
Please help me. I appreciate any assistance in advance.
MarcoAT31
(Marco At31)
February 10, 2025, 5:29pm
3
Hey Mayhem_SWE
I do not know how to make the code confirm, but does this screenshot work?
- id: '1739188797734'
alias: 'Vorhaus Eingang Bewegungsmelder ausschalten'
triggers:
- platform: state
to: 'on'
for:
hours: 0
minutes: 0
seconds: 10
conditions: []
actions:
- service: light.turn_off
mode: single
- id: '1739189174140'
alias: 'Neue Automation'
triggers:
- platform: device
device_id: '133b4f2c3549c7499c39036fbc619f40'
type: turned_on
conditions: []
actions:
- service: cover.close_cover
mode: single
- id: '1739193255571'
description: ''
triggers:
- platform: device
type: turned_on
for:
hours: 0
minutes: 0
seconds: 1
conditions: []
actions:
mode: single
That’s the error code I get, in English:
Home Assistant : New automation has been saved, but waiting for setup has timed out. This may be due to errors in parsing your configuration.yaml
file. Please check the configuration in the Developer Tools. Your automation will not appear until this is corrected, and the automations are reloaded. Changes to the area, category, or labels were not saved and need to be reapplied.
MarcoAT31:
Ahh. That seems to be an issue with HASS since the first releases this year. Was supposed to have been fixed in 2025.2 but there are still people running into this same error. No idea what the solution is unfortunately, but it probably has nothing to do with your automation itself. If anything it may be some integration you are using which is too slow to update.
Do check whether your configuration.yaml
file includes the line automation: !include automations.yaml
as this can also cause this problem.
opened 10:30AM - 07 Jan 25 UTC
### The problem
Since updated to 2025.1.0 I get the following message:
"Your… new automatisering has saved, but waiting for it to setup has timed out. This could be due to errors parsing your configuration.yaml, please check the configuration in developer tools. Your automatisering will not be visible until this is corrected, and automatiseringen are reloaded. Changes to area, category, or labels were not saved and must be reapplied."
I included in my configuration.yaml:
script: !include scripts.yaml
Edit: Despite the message newly created automations are being executed.
### What version of Home Assistant Core has the issue?
2025.1.0
### What was the last working version of Home Assistant Core?
2024.12.5
### What type of installation are you running?
Home Assistant OS
### Integration causing the issue
Automations and Scripts
### Link to integration documentation on our website
_No response_
### Diagnostics information
_No response_
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
_No response_
### Additional information
_No response_
MarcoAT31:
There is a button </> in the forum post editor toolbar to mark up code. Pretty please never post screenshots of code.
MarcoAT31
(Marco At31)
February 10, 2025, 6:34pm
5
Thank you so much, for your help!!
I tried to put - automation: include automations.yaml
in the configuration.yaml
, but it doesn’t work.
So is there a possibility to downgrade the home assistant?
Core: 2025.2.1
Supervisor: 2025.02.0
Operating System: 14.02
Was it not there already? If it wasn’t, it should be included at the root of the configuration, and should not have a dash in front as you’ve written it.
It is possible, but really shouldn’t be needed. Perhaps someone else will have other ideas before you go that far.
MarcoAT31
(Marco At31)
February 11, 2025, 7:50am
7
I got an Update today to 2025.2.2, but nothing changes, same message appears.
To reiterate what Mayhem advised, you do have the following at the top of you configuration.yaml
, correct?
default_config:
frontend:
themes: !include_dir_merge_named themes
scene: !include scenes.yaml
MarcoAT31
(Marco At31)
February 11, 2025, 8:19am
9
Now it works, thanks to Mayhem_SWE and LiQuid_cOOled.
I understand root would be the end of the config not the top.
So I put it on the top and it works
Not quite, by “root” at least I mean “with no indentation”. YAML is a positional language – the indentation matters as it is a part of the syntax.
