Automation for my climate
Hello ;
i have a little question ,
for my radiator i try to automate lot of stuff,
my first idea i t was use the preset of climate entity to activate action.
my climate entity:
- platform: simple_thermostat
  heater: switch.test_radiateur
  target_sensor: sensor.lumi_lumi_weather_6f614005_temperature
  min_temp: 15
  max_temp: 24
  ac_mode: false
  target_temp: 21
  cold_tolerance: 0.3
  hot_tolerance: 0
  min_cycle_duration:
    seconds: 5
  keep_alive:
    minutes: 3
  initial_hvac_mode: "heat"
  precision: 0.1
the climate it 's ok, it will work for long time it’s not problem.
i found how to get the preset state.
{{state_attr('climate.thermostat_test','preset_mode')}}
in developpement tools the value is “away”, “eco”…
my question how i can use in automation for my test i try this
- id: '1645205985532'
  alias: Nouvelle automatisation 2
  description: ''
    value_template: '{{state_attr(''climate.thermostat_test'',''preset_mode'')}}'
  condition:
  - condition: template
    value_template: '{{state_attr(''climate.thermostat_test'',''preset_mode'')}} ==
      away'
  - type: turn_on
    device_id: xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    entity_id: switch.relais_cuisine
    domain: switch
  mode: single
But when i change the state like eco to away , nothing happen
do you have any idea what is wrong
ps: sorry for my english , it’s not verry good
thanks ALL
Try this:
  description: ''
  - platform: state
    entity_id: climate.thermostat_test
    attribute: preset_mode
    to: away
  - type: turn_on
    domain: switch
  mode: single
it’s good
i have been found this
    value_template: '{{is_state_attr(''climate.thermostat_test'',''preset_mode'',''away'')}}'
  condition: []
it’s the same , i know but you solution it’s more simple,
Now i want to tiggrer for all mode like an input select .
it’s possible ??
like
condition: []
  - choose:
     - conditions:
option 1 away, option 2 eco …
I think this will trigger on all changes of the preset_mode attribute:
  description: ''
  - platform: state
    to:
I’m a little unclear on your new action requirement. Do you want to always switch the same device on depending on the preset_mode matching the input_select?
Or do you want to turn on different devices depending on the preset_mode matching the input_select?
In fact , i want when i change, the preset, i Will activa or no the schéma of my scheduler.
I have 2 scheduler for my, thermostat, on away on eco
Before i have à input-select. .
If i sélect " auto confort" scheduler auto was activate and the scheduler eco was deactivate
If i sélect manuel, all scheduler was deactivitated
If i select auto ,eco . Scheduler away off, scheduler eco on.
But this automation require an input-select in additionn my thermostat.
I want remove the input sélect, and replace by native preset of climate entity
I think I understand:
  description: ''
    - platform: state
      to:
    - choose:
        - conditions:
            - condition: state
              state: eco
          sequence:
            - # do your eco actions here
    - choose:
        - conditions:
            - condition: state
              state: away
          sequence:
            - # do your away actions here
THanks it’s that
