I have an automation that saves the current state of the hvac system in an input_text.saved_hvac_mode variable. It works great.
` action:
- service: input_text.set_value
value: ‘{{states.climate.lyric_03c32b.state}}’
entity_id: input_text.saved_hvac_mode - device_id: 94a97da7bf6e4112a36b4584feab3d8a
domain: climate
entity_id: climate.lyric_03c32b
hvac_mode: ‘off’
type: set_hvac_mode
I am having more trouble than it should be to restore the previously saved state to the climate device.
This is code from the automation that works. hvac_mode ‘cool’ matches one of the available states.
` action:
domain: climate
hvac_mode: cool
type: set_hvac_mode`
All I want to do is replace the hvac_mode string with the results from this template.
{{ states('input_text.saved_hvac_mode') }}
It just doesn’t seem to work in real life. What is wrong here?
I’ve tried
` action:
domain: climate
hvac_mode: {{ states(‘input_text.saved_hvac_mode’) }}
but that does not seem to be the way to do it.
