Automation help (turn on dehumidifier)
Hi All,
i would like to turn on the dehumidifier (switch.sonoff_1000897089 to on) when the humidity is above 70% (sensor.sonoff_am2301_humidity_2) but only between 7:00 and 22:00. To do it i’ve had to create 3 automation… is it possible to make only one automation? I would like to say: if the humidity is above 70% and the time is between 7:00 and 22:00 turn it on, else, turn it off… is it possible?
Actually i’m using these:
- id: '1571252692300'
  alias: Turn On Dehumidifier
  description: ''
  - above: '70'
    entity_id: sensor.sonoff_am2301_humidity_2
    platform: numeric_state
  condition:
  - after: 07:00:00
    before: '22:00:00'
    condition: time
  - alias: ''
      entity_id: switch.sonoff_1000897089
    service: switch.turn_on
- id: '1571253751848'
  alias: Turn Off Dehumidifier
  description: ''
  - below: '68'
  condition: []
  - data:
    service: switch.turn_off
- id: '1571293954360'
  alias: Turn Off Dehumidifier At 22
  description: ''
  - at: '22:00:00'
    platform: time
  condition: []
  - data:
Possible, yes. Worthwhile, probably not.
However, you could easily turn them into two:
  description: ''
  - above: '70'
  condition:
  - after: 07:00:00
    before: '22:00:00'
    condition: time
  - alias: ''
  description: ''
  - below: '68'
  - at: '22:00:00'
    platform: time
  condition: []
  - data:
Great! Thanx a lot! It’s a good improvement!
