Automation help with switches
Playing with automations. Went from knowing zero a few days ago to kind of getting the hang of this. Someone here helped me set up my Ring doorbell and since then I’ve added a thing or two. Just running it by the crowd to see if there’s a better or more elegant way to do this.
Here’s what I want to accomplish (and have accomplished).
Ring my doorbell and it sends me a pushbullet notification (in addition to the Ring doorbell notification which oddly enough isn’t very dependable. The pushbullet works every time perfectly. Then the outdoor lights come on.
10 seconds after you you push the doorbell an MQTT configured wifi outlet comes on. A radio is plugged in and loud music starts playing. I’m thinking German Death Metal or whatever the most dangerous kind of sounding music there is :slight_smile:
5 seconds after that a light pops on in the front room.
It does work but last time I asked this question someone helped me clean up the code somewhat. I’m having too much fun with this.
automation 3:
  alias: 'Doorbell Ding'
    - platform: state
      entity_id: binary_sensor.ring_front_door_ding
      to: 'on'
    - service: switch.turn_on
      entity_id: switch.ge_12722_onoff_relay_switch_switch_3_0
    - service: notify.mypushbullet
      data_template:
        title: "Doorbell"
        message: >-
          Someone at the door, Intruder Alert!
    - delay:
        seconds: 10
      entity_id: switch.living_room_outlet
    - delay:
        seconds: 5
      entity_id: switch.front_room_light
Seems pretty clean to me…only thing I would maybe consider is taking all actions and putting them in one script which you can then also call from other triggers. But you could also just add triggers to this automation…that very well may be my background as software engineer. Wanting small bits and pieces to put together later.
~Cheers
You need to get TTS going as then it gets really fun… Your automation looks good. Any way to snap a photo with the ring and attach it to the pushbullet notification?
