Automation - Initial State Toggle
I want to be able toggle the initial_state of automations. This is available on the “Automations” tab in config (see image below). But I want the toggle to be available for some automations on my personal lovelace screens. Is it possible (without introducing an input_boolean)?
You will just need to create an entities card with the desired automations included. Then those automations will be listed and will be able to be turned off or on.
That easy :slight_smile: … here i was trying service calls and other weird stuff. Thanks for the tip @finity
