Home Assistant Supervisor Add‑on, that visualises every automation in your instance and the live state of every entity it depends on. Broken or unavailable entities are highlighted so you can spot problems before they break your automations. You can filter, search and suppress working automations with no issues, and colour coded filter to easily see unused automations.
The idea is to see the live information for the entities to ensure everything is reporting in correctly, check values, check dependencies. Or maybe you missed something that you’d like to add to your automation.
