This blueprint allows you to trigger the siren of your Meross Hub (MSH400 or MSH450) in a continuous 3-second loop using local meross_lan HTTP requests. It will sound indefinitely until the input_boolean switch is turned off.
Requirements
- meross_lan integration installed and configured in local MQTT/HTTP mode.
- An input_boolean (Toggle helper) to act as the master switch.
- The 32-character Hardware UUID of your Meross Hub.
Blueprint Code
blueprint:
name: "Alarma Meross: Solo Sirena en Bucle"
description: "Hace sonar el Hub Meross en bucle continuo cada 3 segundos al activar el interruptor, y lo silencia por completo al desactivarlo."
domain: automation
input:
switch_control:
name: "Interruptor de Control"
description: "El ayudante alternar (input_boolean) que activa y desactiva la alarma."
selector:
entity:
domain: input_boolean
meross_hub_id:
name: "ID del Hub Meross (Sirena)"
description: "El UUID de 32 caracteres de tu Hub MSH400 o MSH450."
selector:
text:
alarm_song:
name: "Sonido de Alarma"
default: 2
selector:
number:
min: 1
max: 7
mode: box
mode: restart
- platform: state
entity_id: !input switch_control
to: "on"
- platform: state
to: "off"
- choose:
- conditions:
- condition: trigger
sequence:
- repeat:
while:
- condition: state
state: "on"
sequence:
- service: meross_lan.request
device_id: !input meross_hub_id
namespace: Appliance.Config.Alarm
method: SET
payload:
config:
- testSong: !input alarm_song
enable: 1
volume: 100
channel: 0
- delay: "00:00:03"
- conditions:
sequence:
method: SET
payload:
config:
enable: 0
volume: 0
channel: 0
