I have a very simple automation, or so i thought , but its been a while since i did stuff with automations
I want to have HA send and alert if my aquarium is below a certain temperature.
I can see the temp on the sensor in my dashboard and in the automation and to test I had set it to below 25 degrees c for 30 seconds, which should trigger it almost instantly but it doesnt. When i run the automation automatically it sends the notify to my phone fine, what am i missing here?
Below the yam of my automation
alias: New automation
description: ‘’
triggers:
trigger: temperature.changed
device_id: 42971166ec103e9447f788f7cb8c99f7
options:
threshold:
type: any
conditions:
condition: temperature.is_value
options:
threshold:
type: below
value:
active_choice: number
number: 25
unit_of_measurement: °C
behavior: any
for:
hours: 0
minutes: 0
seconds: 30
actions:
action: notify.send_message
metadata: {}
message: Temp sensor Aquaone below 25 for 5 minutes
title: Aquarium temperature alert
entity_id: notify.sm_a057f
mode: single
Please format your code using the </> button as formatting and indentation matters if you want help.
Check the traces for the automation and let us know what it says.
Use numeric state instead of device for it to work correctly.
If not try removing the wait time, this is just guessing that your sensor is updating more often than 30 seconds, therefore the time will never complete.
When automations are run manually, it just runs the actions… any conditions you have are ignored.
It still requires a state change, so if the temperature isn’t changing, the trigger won’t fire. For testing purposes, can manually change the state using the State tool.
I don’t see any major issues with your automation. Check the automation’s debug traces for clues about what is stopping the automation from running.
FWIW, one thing I would do would be to limit the trigger to values below your threshold:
